Glad to hear this is working out for you! Did you use the special power connector?this is with an IWILL ZPCgx barebones
This is true. The P1900 does not know that you manually turned off you PC. Why are you manually turning it off anyway? If you want manual control over the PC you should add a "valet switch" on the ingition line. This way the P1900 remains in control of the ACPI signal but you can still have non-ignition-switch control over the startup/shutdown.If start the car, the p1900 sends the signal to turn on the pc. If you shutdown the pc while your car is running, the p1900 does not know this so if
You'll need to find something in your security system that produces a "pulse" per the Pulse Start definition in the manual. Hopefully there's an extra output in your security system somewhere.just gotta figure out how to hook it up to my car's security system so that the unlock will turn on the pc that way widows is up and running once I start the car.
....this WILL be coolThis will be cool.
Thanks for the feedback!
LinkBack URL
About LinkBacks
