Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Yet another m1-atx problem HELP!!
  1. #11
    Constant Bitrate blasterguy128's Avatar
    Feb 2005
    Fort Lauderdale, FL
    I have just soldered the bottom two pins together and it worked. I tested it and everything seemed to be running perfect. So I put everything back together and recoonect it to find out it has stopped working.
    So I whip out the voltmeter and start testing. The problem is I am not sure what is supposed to have juice and what isn't because I didn't test it while it was actually working. So here are my results can you tell me if they are right or wrong?
    Battery + - are fine.
    Fuse is good. And there is juice running through it when + - are connected.
    molex connectors have nothing. (normal I believe)
    20 pin connector- all have 12v (except for white wire) when connected to battery negative. (abnormal I think)
    Ferrite block (FB1)- 3 pins have 12v and the one I soldered has no juice. I thought this was a problem, but when it was working after I soldered it, it also had no juice. Plus the pin next to it had no power. I'm very confused, what should be powered?
    Then I connected the green pin and the ground next to it on the 20 pin connector (cause this turns on a normal psu). Same results.
    I know it will work, I am so close I can taste it. Victory will be mine (with your help). Help me conquer the m1-atx.
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    case= 1/10 scale model of my car (04 Saturn Ion QC)
    soundcard= soundblaster mp3+
    GPS= Holux gm-210
  2. #12
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I'm not an analog expert but most likely, bridging the ferrite bead will probably only marginally reduce the ability of your PSU to block unwanted noise and spikes on the input side.
    You measured 12V on all ATX pins? Uh, that's bad -- and it's hard to imagine a failure mode that would produce such a result without some smoke. Dunno how easily you're going to get warranty support now that you've soldered on the board.
  3. #13
    Feb 2005
    Fort Lauderdale, FL
    Thanks for the help rando, I appreciate it. I think I just joined the "I fried my m1-atx" club.
    I am going to mess with it some more, but I will probably end up getting another psu. Which one, I'm not sure.
    I know the warranty is voided, but do you think I can pay mini-box to repair it?
    Maybe I will just buy a new one and sell this m1 cheap for someone who wants to try to repair it.
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    GPS= Holux gm-210
  4. #14
    Feb 2005
    I blew my M1-ATX earlier this week and sent off an email to mini-box, haven't heard back from them yet so I wouldn't hold your breath.
    However if you want to PM me, I could buy your PSU off you, I've got two blown M1's, between the three of ours I could repair two of them.
    -w
    P4MST-890 775 MicroATX Pentium Dual Core E2140 , 80GB 2.5", OPUS 320W, MS GPS, SB EXTREMEGAMER PCI, 8" LILLIPUT TS, 15" NEC TS, SIRIUS USB PC INTERFACE, STREETDECK, KICKER ZX850.4, KICKER 2500.1, 2xKICKER SS65.2, 2xKICKER 10"COMPVX
  5. #15
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by blasterguy128
    You'd have to contact them to find out.
  6. #16
    Feb 2005
    Fort Lauderdale, FL
    Quote Originally Posted by rando
    I have sent 3 e-mails over a 2 week period and still nothing. But the 1st two were sent to support@mini-box.com and that didn't work so the 3rd I sent to m1-atx@minibox.com. Still no word.
    I have already purchased another m1-atx, but I would still like to get this one fixed. I am going to call them when I get a chance.
    If I can get it fixed then I will explore my options. I could resell the one I just bought, keep one for a back-up, or possibly use two in tandum for more power.
    I don't think I need two m1-atx's in my car, I just don't need that much power. Unless I do two computers...Hmm........O no here I go again...
    I'll post how things turn out. That is if I ever get some support from mini-box.com
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    GPS= Holux gm-210
  7. #17
    Feb 2005
    Fort Lauderdale, FL
    Well, of course, after I just receive my new m1-atx mini-box.com sends me an e-mail.
    It was a very good one though. Basically all it said was give me your address and I will send you a new one. Just send the old one back.
    So I am very happy now, I think it was just a matter of using the right e-mail address. Now I just have to figure out what I am going to do with the 2nd m1-atx.
    Man, I thought since I soldered the board that for sure they wouldn't replace it, guess I'm lucky.
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    GPS= Holux gm-210
  8. #18
    Mar 2004
    Redondo Beach, CA
    Excellent!
  9. #19
    Apr 2005
    NY - USA
    Truck:
    '99 F250 XLT Superduty 4x4
    -Supercab shortbox
    -V10 w/K&N cold air intake
    -Cowl induction hood
    -Flowmaster 2.5's
    Computer:
    -M10000 w/M1-ATX
    -Custom lexan case
    -512mb, 20gb, Lilliput TS, mini-keybrd, GPS, XM
    -Slotload CDRW-DVDR
    -XP, FP
  10. #20
    Variable Bitrate 12Vsystems's Avatar
    Mar 2005
    Orange County, CA
    Mini-box
    I can't vouch for there warranty service. Normally when something dies on our systems we just end up eating the cost but I will say Mini-box makes an excellent power supply. Lets not forget the options here, do you want to go back to the 60 watt morex or mess with a seperate shutdown controller and Voltage Regulator.
    Only problem I have had with our stuff is the 12V line can't provide many amps.
    Spent all my money on carputers now I have to work a real job.
    http://www.858graphics.com
  1. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  2. ATX Pin problem
    By BiohazrD in forum Power Supplies
    Last Post: 05-18-2005, 10:05 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 11:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
