Results 1 to 10 of 20
Thread: Yet another m1-atx problem HELP!!
    Constant Bitrate blasterguy128's Avatar
    Feb 2005
    Fort Lauderdale, FL
    OK...(sigh) This m1-atx has been the most frustrating part of my carpc setup. So everythings was working fine until 2 days ago when it just stops working. Check for problems and find a new fuse got me up and running but with problems.
    The m1-atx wasn't closing the circuit to turn the comp on and off. Then sense I had received the new PIC a couple weeks ago I figured I would try it (big mistake). Now nothings working and its not the fuse.
    Then I notice a wire sticking up from the m1 that I didn't remember being there. I think this is my problem. Here is a picture of it for reference.
    Please help!!! I am out of things to test for.
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    case= 1/10 scale model of my car (04 Saturn Ion QC)
    soundcard= soundblaster mp3+
    GPS= Holux gm-210
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Another Angle pic....???
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Feb 2005
    Fort Lauderdale, FL
    I tried but its hard to get a clear shot. You can't see the wire sticking up? The rest I took came out blurry.
    EDIT: I'll go try another angle.
    EDIT: I tried like 10 angles and that wire hardly shows up. So thats the best pic I got. Sorry
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    GPS= Holux gm-210
    Nov 2004
    Is this the one:
    Nissan Aux-in MOD
    Nov 2004
    I checked the user gide but no wire sticking up:
    http://resources.mini-box.com/online...-ATX-guide.pdf
    Nissan Aux-in MOD
    Feb 2005
    Fort Lauderdale, FL
    Yep...The M1-ATX, its popular.
    This looped wire seems like it popped up.
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    GPS= Holux gm-210
    Nov 2004
    so make abrige and that it!!
    or push it back....
    Nissan Aux-in MOD
    Feb 2005
    Fort Lauderdale, FL
    I tried pushing it back but it won't go. What do you mean by make a bridge?? Sorry I'm not to familiar with circuitry and that sort. Connect what to what?
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    GPS= Holux gm-210
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    That 'wire' is part of the quad ferrite bead block FB1. It should be pushed down and soldered in place. Check the other side of the board. If the solder joint are still in tact, then FB1 is damaged and needs to be replaced. If not, then push the wire down and resolder it.
    Alternatively, if your unit is still under warranty, send it in for repair/replacement.
    Feb 2005
    Fort Lauderdale, FL
    Quote Originally Posted by rando
    Ok, I tried pushing it down but it wouldn't go all the way. Looking at the bottom of the board, the two solder joints appear to still be intact to the board.
    I couldn't just connect the two pins from the bottom of the board? How much of a problem would it cause if the wire doesn't go through the ferrite block?
    I'm trying to get a pic of the bottom, will post if I can.
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    GPS= Holux gm-210
  1. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  2. ATX Pin problem
    By BiohazrD in forum Power Supplies
    Last Post: 05-18-2005, 10:05 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 11:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
