Results 1 to 3 of 3
Thread: OPUS point of load
    Raw Wave lostreception's Avatar
    NY
    OPUS Vehicle Point Of Load DC-DC Converter
    http://opussolutions.com/modules.php...article&sid=26
    This looks promising
    Vehicle Point Of Load DC-DC Converter[U]
    Brief Description
    OPUS Solutions, Inc. Point Of Load DC-DC power supply is designed specifically for powering LCDs, USB hubs, DVD drives, and other peripheral devies that require 5V, 7.5V, 9V or 12V input.
    - 1A - 2A output
    - Wide input voltage range
    - On/Off power switch input
    - High Efficiency DC-DC Power Supply (extended battery life)
    Full Description
    OPUS Solutions Point Of Load DC-DC smart power supply, is designed specifically for powering peripheral devices used in an automotive environment. The Power-ON lead is monitored to start the device when the power is turned on. The input power is protected against transients and load dumps. It also uses technologies to maximize efficiency, performance and reliability. The Point Of Load DC-DC power supply is a step-down regulator, the input voltage should always be higher than the output voltage.
    Sorry if its been posted b4 but it looks new
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    Interesting, they have a 5V, 7.5v and 12v module. Did anyone notice the 9A module?
    Constant Bitrate KaiTech's Avatar
    $36 too...
    I'll spout simplistic opinions for hours on end.
    Ridicule anyone who disagrees with me,
    and generally foster divisiveness,
    cynicism and lower level of public dialog!
  1. Opus 150 and Athlon XP?
    By philstuf in forum Power Supplies
    Last Post: 04-18-2005, 09:05 AM
  2. Opus or Mastero MK-4
    By blackpacu in forum Power Supplies
    Last Post: 08-30-2004, 02:37 PM
  3. Hot Hot OPUS!!
    By god_of_cpu in forum Power Supplies
    Last Post: 06-22-2004, 06:02 PM
  4. Why not buy the pioneer slot load dvd-rom if using 150Watt opus?
    By Mears in forum General Hardware Discussion
    Last Post: 06-21-2004, 02:32 PM
  5. Opus Xformer - Max Load
    By kmfdmk in forum Power Supplies
    Last Post: 03-12-2003, 02:11 AM
