Results 1 to 10 of 10
Thread: OPUS 150 power to caputer no boot
    Sep 2003
    St. Louis
    I have had my OPus 150 in my carputer for about a year now with no major problem
    Carputer:
    Fic Icecube P4 mobo
    celeron 2.0Ghz
    512 ddr
    40 gb 5200 rpm 3.5 hd
    panasonic 7inch touchscreen wired to psu
    no floppy usb dvd drive
    usb navigation
    today dove about 2 miles to get gas before going to work, turned of my car, carputer goes into standby as always. get back into my car nothing comes up. screen is on adn opus power supply fan running as is cpu fan , but no boot. Unplugged opus to reset but same result. pulled carputer out plugged in standard 150 watt atx power supply and booted with out problem. have checked all the grounds and connections and cannot find a thing wrong. my 12 volt comes in at a constant 11.97 is this too little? any suggestions?
    Thanks a bunch
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    curious?
    BossTone74
    May 2005
    Unhappy
    I'm actually having a similar problem, but on a new unit. I have a Shuttle XPC with AMD Sempron 2600. It works fine off of the shuttle PSU, but when I plug up the Opus 150, all the fans come on but the PC won't boot. I've checked the voltage and it's coming in at over 13V. I've even tried disconnecting all the peripherals. Anyone got any ideas?
    May 2005
    Ok, an update. I measured the output on all the pins going to the motherboard with the Opus and with the stock Shuttle PSU. It looks like the -5V rail on the opus isn't working, which would probably explain why the PC won't boot. Guess I'm sending it back and waiting until they replace it.
    Sep 2003
    St. Louis
    where did you test the 5V rail at one of the acc connectors? at the acc connectors I get 11.7 and 4.7. is this too low to power the system fully?
    May 2005
    That should be plenty according to the readings I got. I tested the voltages on the 20-pin connector on the motherboard. Here's what I got with the stock Shuttle PSU and with the Opus 150.
    Shuttle:
    Red = 5.16V
    Yellow = 11.61V
    Orange = 3.35V
    Blue = -12.36V
    Green = 0.20V
    Gray = 4.02V
    Purple = 5.07V
    White = -5.06V
    Opus:
    Red = 5.13V
    Yellow = 12.41V
    Orange = 3.47V
    Blue = -12.67V
    Green = 0.06V
    Gray = 4.29V
    Purple = 4.97V
    White = 0.00V
    May 2005
    Hmm, found this site:
    ATX Connector Pinout
    That said that the white wire might be no connection. It looks like the -5V might only be used on motherboards with ISA slots? Now I'm lost again as to what the problem is...
    Sep 2003
    St. Louis
    I still have no clue whats going on with my system. I will have to call Opus on tuesday. If anyone has any ideas, stoot them my way
    May 2005
    NYC
    we might not be in the same boat, but maybe we're in the same body of water:
    opus120 won't start comp
    Mine is brand new though, haven't had it running yet off the opus.
    May 2005
    Well, they found the problem. Even though the whole system only draws about 100W, it's overloading the 5V rail. The Opus 150 maxes out at 10A and my system with just processor and memory was drawing 13A, and with video card 17A. It looks like I'm just going to have to go with an inverter. Maybe I can get a pure sine wave one.
  1. I need the p4 power cable for the opus 150 for shuttle pc!
    By customalti05 in forum Power Supplies
    Last Post: 05-23-2005, 02:31 AM
  2. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 02:16 AM
  3. Opus 150 and System issues
    By septicdeath in forum Power Supplies
    Last Post: 09-16-2004, 11:38 PM
  4. Opus 90 boot time.
    By shak in forum General Hardware Discussion
    Last Post: 09-07-2004, 04:46 PM
  5. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
