it looks like a keypower. there cheaper then that other places i found, i guess they dont servive angine crank and they have no startup/shutdown controller
http://www.voxtechnologies.com/Power...es/vtc0144.htm
I was quoted just under $200. I may give it a try instead of the inverter/120v PSU route.
Some people say that they survive engine crank.
I'm not to terribly concerned about it surviving crank because if I'm in the car its going to be running. Being in the middle of the desert you dont really want to sit in a car without the air conditioning going. Again not really concerned about a shutdown controller either. Starting up and shutting down manually doesnt bother me much.
I found a interesting PSU on ebay today that I decided I would try.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
I'll let you guys know how it works out. It should be enough juice to power my system.
Asus A7V400-MX board
AMD XP 1800
256Mb Ram
Onboard Video, Audio, Lan
802.11g PCI card
92mm Zalman Heatsink
2 50mm fans, 1 80mm fan.
LOL that wont even come close to powering your system. Its not really 200w. Learn to research first before impulse buying.Originally Posted by schapman43
Opus 150
Keypower
Sproggy
are you your options your looking at around 200 bucks
Originally Posted by antimatter
Care to explain at all? Or are we just making assumptions? The item is described as a 200W ATX power supply.
Here are the specsOriginally Posted by schapman43
for your special power supply needs
PW-200M SPECIFICATIONS
Volts (V) Max Load (A) Peak Load (A) Regulation %
5V 6A 10A +/-5%
5VSB 2A 10A +/-5%
3.3V 6A 10A +/-5%
-12V 0.1A 0.2A +/-10%
12V 12A 13.5A N/A
Power Ratings (Max. Power = 205 Watts)
Efficiency Ratings
Dimensions 61mm (L) X 57mm (W) X 30mm (H) (1U compliant)
DC-Jack 2.5mm X 5.5mm X 10mm
ATX connector Molex 39-01-2200
Overload Protection Over load protection will be effected when either of the loads (+5V & +3.3V)
exceeds > 200% Max Load.
Turn-on Delay After turning on, at least 20ms will be needed for the rise of +5V output voltage (measured from 10% point to 95% point on the waveform) to reach its peak.
Remote ON/OFF control
Logic level is LOW - Output voltage is enabled.
Logic level is HIGH - Output voltage is disabled.
Operating Environment
Temperature 0ºC -75ºC (32ºF -167ºF)
Relative Humidity 10%-90%, non-condensing
Altitude 50,000 ft.
Efficiency Over 95% at full load
Shipping and Storage Temperature -40ºC- 90ºC (-40ºF -194ºF)
Relative Humidity 5%-95%, non-condensing
MTBF 200,000 hours
Warranty 1 Year
Will the PW 200 M work for my setup?Originally Posted by schapman43
You'd do well to ignore the backbiting in that thread....
Originally Posted by DarquePervert
Thanks for the info DarquePervert! It was actually informative. You could have just been an *** and laughed like someone else I know.
