it wont make a differance, the 2 circuits are seperate, they are isolated from each other in the relay
Well, my DC-DC has been running a bit... well the ITPS... well you get my point, very unstable. I've decided to experiment with an inverter. I've got a relay nearly hooked up so that it cuts the power to the inverter when the ACC is switched off. In short, which method will make for a better ground (read less heat, less noise)? Thanks!
1
2
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Signature: [==||========] 20% complete
