Results 1 to 4 of 4
Thread: Remote for amps
    Apr 2005
    Remote for amps
    Ive spliced one of the molex connectors from my PSU to power my xenarc.
    Can i use this same yellow cable to hook up to my two amps for remote?
    So when i switch my comp on my screen and two amps turn on.
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    dude, dont double post!
    just wire it your Acc line so what when the keys in its on, if you do it with the pc you will get a pop when it powers up.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Apr 2005
    Okai, so i can just use the wire that plugs into the ciggie lighter?
    I just attach another wire to this so it can extend to the boot, splice it into 3 ends.
    One for the relay for the inverter, and the other two ends go to each amp, yes?
    So when i turn the car on, the inverter turns on and the two amps turn on. and the computer auto powers up when it sees power.
    So this way everything turns on when the key is turned.
    Is this right?
    Apr 2005
    Ireland
    Hi!
    I like this solution to powering up and down the amp:
    Windows Service that raises DTR on powerup
    It uses a 12V line in the serial port that is switched on and off by the computer and should hopefully stop the pop from happening. I haven't tried it yet myself but it's part of the plan!
    Hope this helps!
    /Optip
    Renault Laguna II 1.8
    Carputer Install Progress: [|---------] 10%
    Received Lilliput 7" Touchscreen and replacement parts for parts of dash i'm likely to cut!
  1. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 04:03 PM
  2. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
  3. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  4. One remote to control them all
    By liquid_smoke in forum Input Devices
    Last Post: 01-22-2004, 10:00 AM
  5. ps2 pelican remote w/ creative reciever & girder
    By ShinkunoNamida in forum Input Devices
    Last Post: 04-26-2003, 03:00 PM
