i just double checked everything - its all wired correctly as the DSSC support says.
inverter remains on, and there is still a buzzing coming from the PSU. it is not full on, but a buzzing
N
i have a DSSC, mATX, and inverter running currently
for some reason, the relays arent working in that the inverter is not turning off. i have it wired as shown in the attached diagram. the switch is always on.
Chris warned me against relaying into the physical switch. anyone disagree with that?
but it USED to work well like this. Right now if i turn off the car, the system shuts down, but on restarting the car the dssc turns on and goes thru the motions, but the computer never starts up.
and like i said, the inverter is always on.
any suggestions?
[4Runna]
next - wifi
N
[4Runna]
next - wifi
Check out my carputers:
DVD, GPS, MP3, 6.4" LCD Touchscreen, 5" Headrest LCDs, PSone, DSSC, etc.
manual says that the supplied relay connects to VAL.
i have ACC connected to my accessory line
io have the 2 wires connected to RC from each relay
ya i can switch off the inverter and everythign does as its supposed to
[4Runna]
next - wifi
this worked before, i rewired everything... i used lower gauge wires to prevent heat/resistance like you and others had suggested...
i currently have 8g going from the relays to the inverter/chassis grounds, the other wires are 16 or 14 gauge
[4Runna]
next - wifi
Neal, there is no place in the manual where we indicate that the VAL connection should be wired to a relay.
I have a feeling this could be the issue. Either way, if you've burned up your DSSC; we will send you a new one.
i meant cb+, sorry... i'll double check that tho, i've known to f up alot
definitely cb+
how is the supplied relay supposed to be wired?
[4Runna]
next - wifi
everything is setup fine...
i dont know what could be the problem
its as if the inverter isnt responding to the relay... its like its getting no power and then when i try to restart it wont go cause theres no power...
[4Runna]
next - wifi
Your relays don't really make sense to me because you don't have the pins labelled at all. What connections go to what pins on the relays?
