Results 1 to 10 of 10
Thread: OPUS simple question
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I've been unable to understand if the opus 150w cuts completely the drain from the 12v when the pc is OFF (like M1 does)
    or does it keep the 12v under load? if so how much does it drain? can someone with an opus try to check this with a multimeter?
    I 'd but I didn't find an exact answer for this
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by Frankino
    I'd measure it, but my PC is currently offline so do say. It's indoors for now.
    I've left the car with the Opsu in stand bye for 3 days in a row, and the car started just fine, if that's your worry.
    Nov 2004
    Italy
    well.. M1 has two timers, one for shutdown and one for cut power..
    I hope the opus cuts the power in some way, for 210€ it HAS to do this
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    This has been stated here over and over and over again. The Opus 150W ALWAYS powers the +5VSB rail. Depending on your motherboard and peripherals, you could end up drawing upward of 100mA on your supply lines. This WILL drain your battery. There is a simple work around to this problem posted in the forums.
    Here are the measurements you asked for posted over a year ago.
    http://www.mp3car.com/vbulletin/show...0&postcount=18
    BTW, to be accurate, even though the M1-ATX does allow you to shutdown the +5VSB rail also, it will still consume some power (a few mA at most) though this amount is likely to be substantially less than your car already draws while off.
    Romania
    Why does the Opus ALWAYS powers the 5V rail?
    Nov 2004
    Italy
    Quote Originally Posted by rando
    I read your posts few minuts after.. sorry for the post but I'm kinda hurry, I ordered an opus but in this case I'm going to swap it with an M1, I should be in time
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Nov 2004
    Italy
    thinking about the 5vstb problem.. is this 5v signal coming from the PSU to the mainboard or from the mainboard to the cpu (maybe regulated from a 12v in)? I was thinking a simple solution, would be possible to rewire the 5vstb signal to a normal 5v signal coming from the ATX connector? this signal should become off when the pc is OFF and solve the problem, what do you think?
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Mar 2004
    Redondo Beach, CA
    @Cris: It's not he 5V rail, it's the 5VSB (standby) rail. All ATX compliant power supplies do this.
    @Frankino: That's also been discussed again and again and again. If you cut the +5VSB rail going into your motherboard, then it will pull PSON low which signal sthe PSU to turn on. The solution is to use a relay to break the 5VSB and PSON signals whenever the PSU and your ignition is off. If you really want to save time, read the thread, implement the solution, be happy.
    The Opus 90W and M1 don't have this problem because they can be jumper configured to disable the +5VSB rail. The M1 however has a very minimal 12V rail. I doubt it will be able to power your Athlon XP based system.
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    In my old car, I ran the battery down once when I didn't drive it for a week or so. I had USB devices (an illuminated keyboard, optical mouse, USB hub, etc.) connected that the OPUS powered 24/7.
    I just placed a switch on my dash for the power cable going to my trunk. If I'm going to leave the car for more than a day without running it, I just flip the switch off.
    Nov 2004
    Italy
    thanks for the patience
    I was using M1 for the system but it died on his own, it was sufficient for my system without dvd-rom and I was thinkint about coupling it with another psu I have, which is capable to output about 5A on the 12v regulated rail, so I was thinking about using it to power 12v devices like cd or fans
    but I think I'll go with opus.
    and by the way, it's absolutely STUPID that a 200bucks psu is not capable of cut the 5v rail if I want to. I don't bother if it is an ATX specs, I really don't care. I want to cut that damned rail
    come on I don't think it would be so difficult to implement YOUR mod in the opus logic.. I sinecely hope that opus solutions will fix this and implement something like the M1 jumper configuration and maybe an amplifier remote signal, programmable too. This PSU deserves it, especially for his price
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  1. Question about Opus 150w and my motherboard
    By Impalaman in forum Power Supplies
    Last Post: 02-09-2005, 09:22 PM
  2. Opus Question
    By paulpitchford in forum Power Supplies
    Last Post: 02-04-2005, 07:39 AM
  3. Question about OPUS 90Watt & Wake on USB
    By GTPmp3PC in forum Power Supplies
    Last Post: 07-13-2004, 08:29 AM
  4. wiring question about the opus 90w
    By DSM97RS in forum Power Supplies
    Last Post: 03-28-2004, 09:28 PM
  5. Replies: 1
    Last Post: 03-24-2004, 05:55 PM
