Results 1 to 7 of 7
Thread: Opus 120w wiring help.. 2 ground and 12v inputs??
    Jun 2004
    AZ
    OK, just got my new Opus 120W today. I had an M1ATX(not enough juice on the 12v rail beware) and also had the Opus 150w (too big for case).
    The inputs for the battery wiring is interesting. the connector has 2 12v input wires, 2 input ground, 1 remote on, and 1 remote out (for AMP delay).
    Now, I dont think I have to hook up both battery inputs to the same battery line. What I would like to do is use the second set of in put wires for A/C use when I bring the PC in the. I am impressed so far with the flexability of this board. Can anyone help?
    May 2005
    NYC
    I take it you haven't tried to fire up the thing yet? I suggest you immediately hack it together and see if it works. I have to send mine and my motherboard (via M10000) into their tech support because they don't play well together. If yours works, feel lucky.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    did you by any chance get some instructions with it?
    if yes then else goto opus
    Jun 2004
    AZ
    instructions came with it but it just shows -12v ground output 1 and 2 and +12v output 1 and 2. Does not explain the need for both
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    looking at the below diagram, you need to run both sets of positive and negative to the battery.
    Reason : Unknown.
    Jun 2004
    AZ
    Great! I did not see that diagram. Thanks for the help. I ran them both last night. Giving her a test run this evening.
    Jun 2004
    AZ
    works perfect! Amp Remote out works great too, no poping!
  1. Turn-on amp POP Stoppers
    By Gene in forum Car Audio
    Last Post: 12-10-2006, 10:52 PM
  2. Help opus 90pwr supply
    By johncrow in forum Power Supplies
    Last Post: 05-26-2005, 03:46 PM
  3. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  4. Stupid question about OPUS wiring
    By RS3RS in forum Power Supplies
    Last Post: 08-31-2004, 02:33 PM
  5. Opus wiring to Sub
    By H3nrY in forum Power Supplies
    Last Post: 08-05-2004, 03:55 PM
