did you hook them up to the right voltage?
and have you checked that voltage rail with a multimeter to make sure it's at the right level?
And... why the hell do you need dual $150 DVD burners in your car??
I would say that unless your OPUS is putting out the wrong voltage on one of the lines, they probably won't cover it, because if its voltage output is correct then it's up to you to wire it properly.
LinkBack URL
About LinkBacks
