Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Switch Inverter On From Console
    Low Bitrate pastypyro's Avatar
    Nov 2004
    Austin, TX
    My system is up and running great now other than some software tweaking and having to switch the inverter on manually. I have a 12V hot (12 or 18 gauge) wire coming straight from the battery (+) pole to a switch and to the remote input on my amp so I can flip my amp on and off as I please. Is there a way I could use this same remote wire to run a relay to flip my inverter on and off? I was thinking about just tapping the wire before the amp and running that to a relay and grounding the other end of the coil. Would that work? Any suggestions? Thanks guys!
    This is so much more rewarding than an MP3 headunit. I will get pictures up of my setup when I have access to a digital camera again as I just moved off to school.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Simple answer, yes.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Nov 2004
    Austin, TX
    I'll give it a shot. Any suggestions from anyone for a specific model relay for this purpose? I would just pull the switch out of the inverter and wire it up into the inverter.
    Like this? http://www.radioshack.com/product.as...5Fid=275%2D226
    MI
    Yep, that'l work.
    Variable Bitrate numbers's Avatar
    May 2005
    Are you talking about opening up the inverter and changing the wires from the inverter switch to a relay? If so, you should be aware that many inverters draw a moderate amount of power even while switched off. It may not be enough to drain your battery overnight, or it just may.
    Nov 2004
    Austin, TX
    Could you elaborate on that a little more? I have the inverter hard wired now with no problems and I just have to manually flip it on after every time I start the car, which involves opening up the hatch. I haven't had any problems leaving it wired up and flipping it on. Why and how would an inverter draw when switched off?
    May 2005
    Woodstock, GA
    Quote Originally Posted by pastypyro
    I never had any problem with this. I dont have the PC in yet, but I used an inverter for my PS2. When it was off, it was off... no power drain.
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    Low Bitrate odleon's Avatar
    Atlanta
    i did this mod today. step 1, open up the inverter.#2, cut wire going to off (circle emblem) on the sitch. #3. wire one side of the cut wire to post 30 and the other to 87(terminal in the center of the relay, 87a, isnt used).then ground 85 and put acc + on 86.#4 run wire from 86 to a switch power source(remote wire to amp or behind head unit). and thats it. just keep the switch on the inverter on at all times and the inverter will turn on and off with the car. the good thing is that the switch is still there in case you want to turn off the inverter manually.
    hope that helped.
    Nov 2004
    Austin, TX
    Odleon: Did you use that 30 Amp relay from radio shack?
    Atlanta
    cant recall... it is a standard Bosch relay, got it free from work. the radio shack one will work fine tho...
  1. Inverter Switch?
    By Coeus in forum Power Supplies
    Last Post: 02-05-2005, 11:14 AM
  2. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
  3. Voltage going through inverter switch?
    By CoCa in forum General Hardware Discussion
    Last Post: 03-29-2004, 10:57 PM
  4. Power switch for inverter?
    By detz in forum Power Supplies
    Last Post: 06-26-2002, 12:24 AM
  5. can this switch handle my inverter???
    By DJ in forum General Hardware Discussion
    Last Post: 07-25-2000, 08:46 AM
