power on delay must be lower than 200ms. i set it to 100ms and it works like a charm![]()
I connected M1 cables and tried to automatically wake up my PC but it doesn'twhen i disconnect power switch cables from M1 and switch power manually then my PC wakes up and works perfectly. I have read trough troubleshooting section, doublechecked all cables and connections and tried again, but no luck
switching again manually, pc comes up.
Tried same M1 on VIA miniITX mobo, there it worked as it must. But M1 doesn't wake up my aOpen i855GMEe-LFS Pentium M mobo
Any suggestions, what to try what to do to get automatic powerswitch working?
How did you set the power on delay?
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
aopen mobo has that specific feature![]()
carpc install finished:D
http://www.mp3car.com/vbulletin/showthread.php?p=578243
Cruisin on my own...
Thanks![]()
