Results 1 to 3 of 3
Thread: Keeping the power down?
    Jun 2005
    Kent, England
    how do you lot keep the power requirements of your PCs below the 140/150w limit of the opus et al
    the system i'm looking to build has a higher requirement than this. but the ease of use of these power supplies/regulators seems good.
    what other way could i supply +150W and have the delayed shutdown and work off ignition, etc...
    thankyou
    Variable Bitrate numbers's Avatar
    May 2005
    What exactly is your planned setup? Most of the guys with DC-DC psus here run low performance setups, but you just might be surprised at how little power your setup may draw. I'm running a 2500 barton on an nf2 board and I rarely see a draw of more than 10 amps at 13.5 volts. That's only 135 watts peak. Normal draw is closer to 7 amps. (95 watts)
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    FAQ Emporium, item 3 under "Hardware" explains a lot about how the various power setups work and what is used to power higher wattage setups (hint: inverter).
    Want to:
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
