Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: M1 ATX problems
    Jun 2005
    M1 ATX problems
    Hi! I'm writing regarding some problems I have with my new M1 ATX
    DC-DC power supply. My HD does not power up properly, it does not start
    spinning. I have measured the 12V rail to the HD and it measures 11.1V when my VIA-bord is turned on and 4,4V when when the computer is turned of, which I find a bit strange. I have 13,9V at the battery when the car is running so it is not a problem at that end. Also the computer and HD works fine with a ordinary power supply. I only have the HD and motherboard hooked up to the PSU. Everything is OK with the 5V rail. I have mesured all the voltages both loaded and unloaded and they are the same.
    Do you have any idea on what the problem can be??
    Best regards
    /Tomas Berglund
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    post your configuration, maybe M1 cannot handle it properly
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Jun 2005
    I have the following hooked up while testing:
    VIA M1000
    256 MB
    Seagate 3,5" 160 GB HD
    As I mentioned earlier I have tested both with and without the HD.
    /Tomas
    Nov 2003
    My gues is that your Inoput voltage is to low, it needs to be more then 12V.
    Try to test it with the motor running.
    Cheers,
    Remco
    Jun 2005
    As stated in the first post I have at least 13,9V when the car is running.
    /Tomas
    Unless that hard drive is taking alot of amps on the 12v rail then you may have a bad psu. I'm a little suprised that your 12v rail is at 11.1v though. Normaly they are within 12v-11.5 (the lowest I'v ever seen on any psu). This leads me to think that it may be a bad psu.
    Constant Bitrate FociMan's Avatar
    Jun 2005
    Gloucestershire
    I agree, if your voltage reading is correct then 11.1v is too low. A 3.5" HDD draws more power than a 2.5" laptop HDD, but the M1-ATX should be able to cope with it. Sorry to say it, but I think you have a duff PSU.
    FociMan
    Ford Focus Collection
    EPIA M10K / 512Kb / Creative Audigy NX USB
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Bluetooth GPRS Web Connection
    Centrafuse Beta2 / MapMonkey
    Variable Bitrate 12Vsystems's Avatar
    Mar 2005
    Orange County, CA
    re
    Would have to agree with these guys we use the same power supplys and always see 12v even when the battery voltage is at 12v.
    If you want to quickly get around the problem hook up a 2.5" drive the use an unregulated 5v line for power.
    Spent all my money on carputers now I have to work a real job.
    http://www.858graphics.com
    Apr 2005
    NY - USA
    Truck:
    '99 F250 XLT Superduty 4x4
    -Supercab shortbox
    -V10 w/K&N cold air intake
    -Cowl induction hood
    -Flowmaster 2.5's
    Computer:
    -M10000 w/M1-ATX
    -Custom lexan case
    -512mb, 20gb, Lilliput TS, mini-keybrd, GPS, XM
    -Slotload CDRW-DVDR
    -XP, FP
    Jun 2005
    OK! I have allready ty tried to get in contact with them and no luck!
    Today I messured how many amps the computer wants when I turn it on, around 2,1 A @14,3V. What do you guys think about this??
    /Tomas
  1. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 08:12 PM
  2. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 04:28 PM
  3. Opus atx power (on off) like this?
    By Mad Ad in forum Hardware Development
    Last Post: 05-08-2005, 08:11 PM
  4. atx supply problems
    By oddcomp in forum Power Supplies
    Last Post: 10-21-2002, 11:05 PM
  5. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
