Results 1 to 10 of 18
Thread: Inverter: continuous power consumption?
    Apr 2005
    Hello just another technical question which is not clear to me:
    When the carputer is off, will the inverter always continue to draw power from the battery if not switched off?
    thanks in advance,
    -m
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    oh for god sake dude!
    AND TO ANSWER YOUR QUESTION BEFORE YOU COMPLAIN:
    of course it uses power if you dont turn it off!
    Apr 2005
    ok ok, so sorry...
    Variable Bitrate numbers's Avatar
    May 2005
    Don't mind him. Yes it will draw power. Nothing to worry about if you're just leaving for a few hours, but don't expect your battery to have anything left after leaving it overnight.
    Mar 2001
    Some inverters have 'cooling fans' that continue to run after the computer has been turned off. Fans consume a significant amount of power (as compared to discrete components).
    Check out my carputers:
    DVD, GPS, MP3, 6.4" LCD Touchscreen, 5" Headrest LCDs, PSone, DSSC, etc.
    Apr 2005
    Well thank you for the answers.
    So if I understand it is not a continuous output of (let's say) 300W.
    Power consumption goes accordingly with the power drainage.
    So if the carputer stays off the draining will be drastically lower.
    Is this correct?
    Mar 2004
    Bristol
    GRRR
    yeah buddy, the inverter wont draw 300W unless it is under a high load. It can output 300W so expect the input to be over 300W (due to ineficencies) when calculating the wire and fuses required. But then again I would never draw 300W from a 300W rated inverter. Always keep a healthy margin.
    Whn the PC is off it will draw a small amout of current but this will kill your battery in short term and long term (ie car batteries don't like constant draws and will eventually go tits up on you).
    You need to use some sort of isolation (relay etc) or just turn it off. There are planty of ideas on here so have a look round.
    one more thing: always hook up your inverter to the batttery not the ciggy lighter and put a fuse on the +ve lead as close to the battery as possible. Also, do not mount your inverter in your engine bay (we had one guy do this).
    Jul 2005
    my monster power inverter says to unplug it when not in use for about a week since it imposes a constant power drain even when switched off...i'm assuming for monitoring temps and turning on/off the fan accordingly
    Newbie ozms's Avatar
    Jun 2005
    Manassas, VA
    depending on your 12v outlets in your vehicle it might not draw anything out of them. in my truck when the key is off the convenience outlets are off. to include the cig lighter. but in some cars they always stay hot... best way to take the guess work out of it is to shut your car down and use a multimeter and measure the output of the socket. or connect a solar cell to your battery to keep a constant charge on it.
    Dec 2004
    Where its windy
    A lot of inverters on the market still draw a small amount of power even when switched off. This is why you use a relay.
  1. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  2. 800 watt coleman power inverter
    By FishPony in forum Classified Archive
    Last Post: 04-21-2005, 03:50 AM
  3. Wiring Power Switch With Inverter
    By Jiroe in forum Power Supplies
    Last Post: 10-29-2004, 06:27 PM
  4. Replies: 4
    Last Post: 10-29-2004, 09:10 AM
  5. Power consumption
    By Jimbo1978 in forum General Hardware Discussion
    Last Post: 07-07-2004, 11:00 AM
