Results 1 to 6 of 6
Thread: Delay device
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Delay device
    What is the most cost effective way to introduce a... say 5 second delay into a circuit for powering up things? My computer will only start after the inverter has been powered for a few seconds, and if I try to hit the on button before then it continuousally faults the inverter, resulting in loss of power, resulting in the relay hitting the on button again, which makes another fault.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Building a simple delay circuit is very cheap (<$5) if you don't mind doing a bit of soldering. You should be able to find past threads discussing this, and google will get you any number of circuit diagrams as well.
    Mar 2001
    A shutdown controller is probably overkill here, but we're running a very limited sale on the DSSC for a couple of days.
    It will easily do more than what you want.
    Check out my carputers:
    DVD, GPS, MP3, 6.4" LCD Touchscreen, 5" Headrest LCDs, PSone, DSSC, etc.
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by bergeron76
    I would, but im trying to homebrew my startup/shutdown solution as much as possible right now its running on 5 auto relays.
    Variable Bitrate markland556's Avatar
    Jun 2005
    Bellevue, WA
    holy monkeys only $30 im getting one. Crap my paypal account is still locked from some jerk trying to rip me off.
    96' Mercedes Benz C36 -Matte Black-
    Status..::... {##------}25%~~ back to planning
    Mar 2005
    Pomona, CA
    Question about the DSSC. Can I set it to wait 5 seconds or so before turning on a monitor? More importantly, is there a way to make it press the button so to speak for 5 seconds and then stop?
    Edit: Scratch that. Looks like I can simply set a 5+ second delay and then have it pulse the power to make it as if I waited 5 seconds and then pushed the power button on my LCD. Went ahead and ordered one. Cannot beat $29.
  1. lilliput won't work - USB device not recognized...
    By aegray in forum Input Devices
    Last Post: 06-16-2009, 02:38 PM
  2. Replies: 5
    Last Post: 05-28-2006, 04:52 AM
  3. Replies: 12
    Last Post: 09-23-2004, 02:00 PM
  4. What GPS device should i get ?
    By eazyrog in forum GPS
    Last Post: 04-29-2004, 11:14 AM
