Results 1 to 6 of 6
Thread: Bridge batt power for relay switch?
    Apr 2005
    Okai at the moment i have my inverter hooked straight up to the battery. Fuse at the battery end of power cable.
    Just before the power reaches the inverter i have a relay which is hooked up to the acc line.
    So when i crank my car, the computer reboots, not because of low voltage but because acc line cuts out when cranking.
    So instead of using the acc line, can i splice the power cable that goes to the relay and just hook the switch at my dash to this and then to the switch on the relay.
    So basically i just replace the acc line thats switching my relay with a permament batt line.
    This should be okai yes?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    can you just put a delay on that? maybe a simple cap and resistor? that way the relay would stay open during crank?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Apr 2005
    mmm, thank you, never thought of that, will do.
    Apr 2005
    Actually i want to be able to keep the comp on when i take the keys out, say i go to fill up petrol i dont want to leave my keys in the car.
    So for this i need the power for the switch on the relay hooked up to a permament 12V.
    So is it safe to hook the relay switch line directly to the battery with a small switch inline so i can switch the relay open/closed?
    Also does the acc line become a 14.4 volt line when the car is on because of the alternator, or does it stay at 12?
    Jun 2005
    I believe that the Acc. line stays 12V because it is regulated by the voltage regulator. I think this is true. If someone could verify this that would be nice .
    BTW; I'm new here. Hi!
  1. power switch
    By hot_98_civic in forum General Hardware Discussion
    Last Post: 06-07-2005, 12:57 AM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  4. Wiring Power Switch With Inverter
    By Jiroe in forum Power Supplies
    Last Post: 10-29-2004, 05:27 PM
  5. Replies: 13
    Last Post: 09-20-2004, 06:01 PM
