Sorry I can't suggest anything to help you, but I have suffered similar issues with a new Gigabyte MicroATX board and Celeron D 2.8 CPU.
I'll be waiting with anticipation for you to post the response from Opus on this one.
I received my 150w "naked" opus yesterday, wired it, everything ok
led blinks OK, then ACC on and the pc starts to boot fine
Windows XP bootup logo, 5 sec, 10, 20, 60, Blue Screen Of Death
it won't boot properly
I plug my standard ATX psu and it works oerfectly, boots up and goes into stanby. I replug the opus, pc starts and wakes up from standby but it's VERY slow, it take about 5 min to do a complete shutdown. After that it won't boot, it still hangs on Windows bootup logo.
I think it might be related to poor 5v rail but it's 10A, same as M1 and same as my old DC-DC, and with both of them it works perfectly, but I've gotr 12v overload issues so I purchased an Opus.
don't know what to do, I tried to power up the hard drive using another ATX psu, same problem.
the configuration is pretty soft..
amd xp-m 2500+ (but it boots up at 600mhz...)
256mb ram
ecs mainboard with audio-video-lan-usb
20gig 2.5" hdd
dvd-rom
I tried to remove dvd rom, same problem
the entire pc drains about 4A from the battery.. I was thinking about checking the 5v drain from the mainboard, where should I check this value?
by the way, it is really NOT supposed to give 5v overload problem..
any ideas?
Below I quote the email I sent to the Opus support..
Originally Posted by Opus email
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Australia's Largest CARPUTER Discussion
www.carputer.net.au
well I think cel 2.8 needs is far mor power than my mobile athlon @600mhz
somehow I'm sure I won't solve this problem..![]()
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
try to clear the cmos and and even try installing windows again from the car pc running off the opus if you havent already
update the bios on your motherboard too maybe
at what purpose? my pc works perfectly with a standard atx power supply, it freezes as soon as I power it up using the opus
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
Sounds like the opus is defective... send it back. Have you tried powering another mobo off the opus? I bet it does similar crap. Also... does your mobo have cpu throttling, and if so, is it enabled? that can cause issues with power consumption.
Good Luck.
Carputer status: [-*---------]
Im thinking laptop...
guys, this is weird, really
I built an ATX cable to easy check voltages and drain for each rail
I did some tests, 2.5A on the 3,3v, 3,5A on the 5v and 1,2A oh the 12v rail
as you can se,, well into opus specs.
but this is NOT the weird part
during my tests I checked 12v, then 5v and then 3.3v
well, when I was testing the 3.3v drain (placing my tester between mainboard and psu) I noticed that the pc for the first time booted up fine. ok, it's a coincidence. I remove my tester and repower the pc and the pc won't start. Ok. Then I reconnected my tester (again in serie) and my pc power up normally. I started to think it couldn't be a coincidence again.. well after about 10 times removing and replugging my tester I come to the fact that if I connect the my tester the system boots up properly; if I remove it the systen won't start. I cannot believe myself when I realized it but, guys, these are the facts. Does anyone have the slightest idea what's going on?
by the way, my tester reads 3.44v at the 3.3v points, I don't know if it may be a problem
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
Have you thought of soldering your tester to the carputer? hahahahaha
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
heres my take on your problem
the tester draws current (adds resistance)- the opus provides current so it works
your current pc and mobo dont draw enough current to get the opus into its operating range, and hence its pushing out wussy current. The opus is probably designed to only push out as much as is required, the mobo doesnt draw as much as is needed to kick the opus into doing something. there is a formula to explain what I am talking about - current draw but havent a clue how to explain it in other words
you need to think a little out of the box here, i would try your pc with the proper clock speed and all and add as many peripherals as you can.
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
Check the impedance of your tester. If it's a cheap one the impedance may be low and what it is doing is causing the voltage to drop and limiting the current on the 3.3 rail.Originally Posted by Frankino
In theory, you could connect a resistor of the same value as the impedance of your tester in place of the tester (if that makes sense) it would then boot up. (Don't recommend it as a solution though).
It sounds like the Opus is running out of spec on that rail and that is what is causing your problem.
If your tester has a low impedance then the readings you are getting may be incorrect.
It always pays to use a high quality high impedance meter for solving problems like this.
Hope this helps some.
