Results 1 to 10 of 14
Thread: Got my DC/DC converter
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Question Got my DC/DC converter
    Here is the original thread
    Seems well built. Didn't come with any manual.
    Here is my question: the wire from my headrest monitors seems to only be one wire, not a + and -. But on the converter there are 2 wire outputs, + and -. Should I wire to the + terminal only, or am I missing something.
    Attached is a picture of the terminals on the power supply.
    Thanks.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Could be another case of grounding through the input connector - liek you can get with VGA screens. Possibly grounds through the outer contact of the RCA
    Nov 2003
    Marietta, GA
    I'm sorry if I missed something very basic here, but.... why would you spend $89.95 for a +12V/50W regulator...or even $59.95 for a +12V/25W regulator, when you can buy a 60 watt regulator (with several additional features) here in the MP3Car store for $69.95(http://www.mp3car.com/store/product_...products_id=60 ). Sorry if this sounds a little harsh, but I'm not understanding the logic....??
    MikeH
    Mar 2004
    Bristol
    hehe, click his original thread and you will see he got it for $40.
    Nov 2003
    Marietta, GA
    ...ah.. missed the second post.
    MikeH
    Dec 2003
    wrong
    Hey Mike you are right, sorry guys. The regulator is 39.95 or 39.99, but check out their shipping charges $20.00, initially I thought the same, not a bad deal 30.00 bucks less than the carnetix, but after setting up a quick account and trying to buy one I almost **** with the 20.00 shipping to CT. I will pay the extra 10 and get a couple added features.
    Hey Mike how about a small disc coupon for the support.
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by petesonline
    Yeah, I thought that was bad too so I emailed for better rates. Ended up with $12 shipping from Canada to California and it took about 3 days to get it. To compare, shipping the Carnetix would cost $9.61 for me.
    Anyway, I'm not all that informed about this kind of thing. I read that this power supply would be great for powering up to 4 monitors, and I was trying to figure a way of powering my 3 monitors.
    On the other hand, the Carnetix says this:
    The P1260 is designed to be a pre-regulator for CarPC cases that already contain an internal DC-DC ATX PSU, such as the Travla C-134 or the Morex 26xx/36xx cases, or for motherboards with on-board DC-DC PSUs (VIA TC10000).
    I honestly have no idea what all that means except that its not saying it'd be perfect for powering 3 monitors. If I missed something then thats my fault, but I figured its always good to find which products out there might work for us and test them out.
    So, back on topic: Anyone have a thought on wiring this to my monitors?
    FLAC edrex's Avatar
    Dec 2004
    Ok, dug a little further into the power line from the monitor. Attached is a pic.
    There is about 4 times as many wires on the outer layer then there is on the inner isolated wire.
    Can I safely assume that you need more wires to power then to ground and attach the thin inner wire to ground and the outer wires to positive?
    Thanks.
    Mar 2004
    Bristol
    normally the outer wire is ground.
    you could check by taking the screen apart and seeing if there is a reverse polarity protection diode and work out which is which from that.
    Mar 2004
    Bristol
    they are normally done like this for those power conenctors with the positive on the inside (female part) and the ground on the outer part.
    EDIT: the ground is then passing down the outer shielding - it is done liek this with RCA connectors too.
  1. DC/DC Converter for Screens
    By edrex in forum Power Supplies
    Last Post: 06-14-2005, 01:21 AM
  2. DC/DC Converter for EPIA ITX
    By dubje in forum Power Supplies
    Last Post: 12-22-2004, 07:12 AM
  3. DC/DC Converter
    By AceRimmer in forum Power Supplies
    Last Post: 09-29-2004, 01:07 PM
  4. DC/DC Converter from cartft.com
    By mashina in forum Power Supplies
    Last Post: 09-11-2004, 08:27 AM
  5. FS : ITX P4 Mainboard and DC/DC Converter for Travla C134/C150
    By VooDoo1999 in forum Classified Archive
    Last Post: 03-05-2004, 03:15 AM
