You could, but that would require an inverter, not the best solution, if its an ATX Motherboard then it should run from any atx power supply,
Can i use the power supply from a normal big atx box to power a micro atx board? or do you need special micro atx power supplies.
P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
Yeah the inverter is no the best option but I can be done with no problems.
Check for DC-DC PSU like the OPUS or if you are no in a hurry you can wait a week +- and get dragonBTV new PSU with best futures than the opus.
Also check this thread for areference in what you need in terms of power supply:
How do you guys keep things under 150 Watts
