Results 1 to 3 of 3
Thread: Help a newb verify his schematic readings for Opus 150W
    May 2002
    Iowa
    I am about to implement Rando's relay circuit to fix the issue of the constant +5vsb. This was taken from this thread:
    Cutting power to USB after computer has shutdown
    Since I have only a tiny amount of electronics experience I thought I'd double check my work here. I drew a picture of my interpretation of the schematic. Please let me know if this looks incorrect. Thanks!
    http://www.sarahsignature.com/images/car/Relay.jpg
    5% Complete
    Dash Fabrication complete
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Looks good except your +5VSB and PSON connections to the relay. You need to have a +5VSB wire on the N.O. and Common connection. You need to have a PSON wire on the other N.O. and common connection.
    Here is your diagram fixed.
    May 2002
    Iowa
    Many thanks to you! I appreciate your work Rando.
    5% Complete
