bump, no one has any info? maybe im in the wrong section
when my epia MII 12000 motherboard goes into standby the cpu fan continues to run till the machine goes into hybernate. Is this normal?. My last carputer(P4 with FIC motherboard) shut down the cpu fan when in standby. is there a bios setting?
same thing here, same mobo too.
it has something to do with S1 / S3 ACPI setting in the bios, if I remember correctly in S1 state fans continue to work, in S3 everything is dead. Check your bios for this setting
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
It needs to be the S3 setting I found it after I read some more of myThanks
