You are right, there are no "cheap" stuff when it come to "power".
Search tips: DC-DC, Inverter.
You will find tons of info.
I have a car player (almost complete) and I was wondering if anyone knew of a cheap solution to this problem.
In the house, I have to use a AC power supply, but i would like to find a converter to convert 120vac to 12vdc required by the players internal power supply.
I have done hours of searching with no (cheap) results.
ANy help would be greatly appriciated.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
tr100a120 at http://www.psui.com/ should do the trick.
Actually, Here's an easy and cheap(er) way to do it.
I got some alligator clips from radioshack, and had an old Power Supply lying around. I disconnected the 12v cables from the power supply, stripped the ends, and soldered them to an alligator clip. I did the same with some ground cables, and voila: A 120vAC -> 12vDC power converter.
Then, I also soldered the PSON motherboard port on the ATX plug to a ground to make the power supply turn on when it got power.
I plugged the leads that I just made into the leads from my DC-DC power supply, , turned them both on, and it worked great.
Just thought this $5 (maybe 30 if you dont have a Power supply lying around) solution beats the $60+ competition.
Some Pictures:
I have a Dell Power Supply, so colors and layout will be different than standard ATX.
Ground and +12v leads + alligator clips.
PSON connected to ground w/ solder and wrapped in electrical tape.
My leads connected to the leads from my DC-DC power supply (in my player)
General setup. You can see my modified power supply (silver thing in the middle), and my player (big black box).
I did the same thing but I think that grounding the PS-ON atx signal is a better way to auto power up the psu, it's the default way
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
