Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: opus 120 problem
  1. #11
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by UM_Fan
    I have not tried that...My volt meter is somewhere/someone has it....
    I tried looking for....Since I did not find it I turned to the "Pros"
    Oh, I thought that you did this since you had mentioned you had checked your connections Ya, definitely check that.
    Installed.
    -GPSSecure- - GPS Tracking
  2. #12
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    Quote Originally Posted by techy101
    I know I mentioned it once, but did you check the fuse on the Opus itself?
    Yup I pulled it out and checked it...it was good
  3. #13
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    Let us know what happens when you meter the lines. Once you find your MM
  4. #14
    Feb 2005
    Miami, Florida. 305
    Question...with the stuff I have (on my first post) will the opus 120 handle it?
    I know...noon question...just wanna double check...
  5. #15
    Minneapolis, MN
    It seems like it should.
    I've got an OPUS 150 running:
    P4 2.8GHz
    512MB RAM
    ATI Radeon 9250
    120GB Maxtor 3.5" HDD
    External USB DVD enclosure
    GPS Mouse
    USB wireless card
    DWW-7VGA
    All powered from the OPUS. It's running just fine. So your setup shouldn't have any problems
  6. #16
    Feb 2005
    Miami, Florida. 305
    after a long hot day (miami) installing....I went outside the next day, just to doulbe check my work...since the opus wouldn't start...and such an *** I over looked one of my cables...The ground wire was not connected..
    Now it's all working opus, works just fine......all the sweet, cursing, mosquito bites and sometimes regretting....Now time to enjoy
    Now I have hibernation issues....
  7. #17
    Minneapolis, MN
    hah, I know how that goes. Orlando here. glad u figured it out
  8. #18
    USA
    Hehe, done that myself many times. Once my screen started going out. Finally it went completely out. I had heard of all the problems with the Lillis so I expected the worst. I pulled the screen out and tried it in the house using the RCA connections first. That worked so then I tried it with a differant computer. That worked so I was like oh crap something is wrong with my video card. After some more investigation I found out that the VGA extension cable I was using had come apart from where it plugs into the Lillis adapter. I didn't see this at first because everything is enclosed.
    Installed.
  1. Opus power up problem
    By baef in forum Power Supplies
    Last Post: 10-23-2005, 08:00 AM
  2. Opus 120
    By Cheekz185 in forum Power Supplies
    Last Post: 06-17-2005, 04:08 PM
  3. OPUS 150 Problem FIX
    By titaniumkingpin in forum Power Supplies
    Last Post: 02-25-2005, 08:31 AM
  4. Strange Opus 90W problem
    By Jailer in forum Power Supplies
    Last Post: 11-02-2004, 02:16 PM
  5. OPUS powerdown problem
    By neutral in forum Power Supplies
    Last Post: 03-10-2004, 10:33 AM
