Results 1 to 10 of 18
Thread: opus 120 problem
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    opus 120 problem
    I just installed evering thing today...
    Here's my setup:
    4G wire
    Remote to subs
    Epia 800
    512 pc133
    40G notebook HD
    Slot loading DVD/CD-R
    USB Hub
    2 L.E.D. Fans
    XM
    TView wiried to the Power Supply
    USB GPS Mouse
    and.....OPUS 120
    I power everthing and worked like a charm...powered up/Power down. After twicking the screen and RR, I rebooted....did not power up
    Now I pulled the PC inside my house and it powered up. No LED on OPUS....Did I burn the OPUS????
    Super Moderator xBrady's Avatar
    USA
    You checked the cables going into the Opus right?
    Installed.
    -GPSSecure- - GPS Tracking
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    Check the fuse inside the Opus, or any fuses you have inline to the Opus too
    Feb 2005
    Miami, Florida. 305
    Check all fuses....there all good
    Minneapolis, MN
    And all your connections? especially any splices?
    Feb 2005
    Miami, Florida. 305
    I checked everthing....all connections, fuses..I unpluged everthing and reconnected....Here's how I have it wired...
    4G-----140fuse----4G------3 way Disto Box (40fuse)----PC
    4G-----140fuse----4G------3 way Disto Box (60fuse)----4Ch Amp
    4G-----140fuse----4G------3 way Disto Box (80fuse)----2Ch Amp
    It worked fine for about 1/2 hour while I worked on the touch screen
    USA
    Sounds like it might be dead if you aren't getting any lights and all your connections are good.
    Installed.
    Minneapolis, MN
    do you have a volt meter/multi meter? Check the voltages on your lines. With the car off you should have the following
    Yellow~12V
    Red~0V
    With the car running you should have
    Yellow~14V
    Red~12V
    Give or take.
    Minneapolis, MN
    I know I mentioned it once, but did you check the fuse on the Opus itself?
    Feb 2005
    Miami, Florida. 305
    Quote Originally Posted by techy101
    Yellow~12V
    Red~0V
    Yellow~14V
    Red~12V
    Give or take.
    I have not tried that...My volt meter is somewhere/someone has it....
    I tried looking for....Since I did not find it I turned to the "Pros"
  1. Opus power up problem
    By baef in forum Power Supplies
    Last Post: 10-23-2005, 07:00 AM
  2. Opus 120
    By Cheekz185 in forum Power Supplies
    Last Post: 06-17-2005, 03:08 PM
  3. OPUS 150 Problem FIX
    By titaniumkingpin in forum Power Supplies
    Last Post: 02-25-2005, 07:31 AM
  4. Strange Opus 90W problem
    By Jailer in forum Power Supplies
    Last Post: 11-02-2004, 01:16 PM
  5. OPUS powerdown problem
    By neutral in forum Power Supplies
    Last Post: 03-10-2004, 09:33 AM
