Yes, It will have a user selectable range. For example it will spit out something like this:Originally Posted by rsd212
a:50
b:-5
c:1
d:0
e:12000
f:300
You will hit P or something to put it into programming mode, then you will either hit enter for the default or change each of the parameters.
for example, a: was the temperature High range, b: was the temperature low range. c: meant that it reads the pots to get the low voltage detect and the main countdown timer. d: means something else... etc..
There will be no external temp probes. The temperature funtion will work a lot better than the uSDC controller.
What kind of features do you want?
LinkBack URL
About LinkBacks
