Page 1 of 7 1234567 LastLast
Results 1 to 10 of 61
Thread: New Mpegbox Power Supply
    Apr 2001
    Portland OR
    Hey All,
    Your prayers are about to be answered.
    Here your looking at the new DSATX Durawatt power supply from Mpegbox.com
    This power supply has the following specs:
    8-16 volts in
    12V @ 11 Amps
    5V @ 11 Amps
    3.3V @ 10 Amps
    5VSB @ 1.5 Amps
    -12V @ 0.15 Amps
    I am going to call it a 220 watt DC-DC power supply.
    Here it is powering a P4 motherboard and hard drive with an 8 volt input:
    Here is the P4 motherboard on the BIOS and my Main PC on the right, it is connected to the power supply with hyper terminal:
    Here is what the power supply is currently spitting out of the serial port every 100 ms:
    Basically this is as follows
    Temp in Degrees C : Input voltage : 12 volt rail : 5Volt rail : 3.3Volt Rail : Pot1 : Pot2 and the YYYN means all the rails are within 5% except for the input which is 7.14 volts (and powering a P4 by the way...)
    This power supply is very very efficient, has a very beefy 12 volt rail, and will have by far the best serial port diagnostic and programmable shutdown controller on the market.
    Any takers? :-)
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    How much are you going to be selling it for? Just asking
    Apr 2001
    Portland OR
    Quote Originally Posted by 0l33l
    Probably around $150 - $200.
    www.mpegbox.com
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Ok......
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    looks good!
    Raw Wave tj!2k4's Avatar
    Oct 2004
    looks nice.. what are the dimensions?
    May 2005
    Woodstock, GA
    when you need some (unbiased) one to conduct real world testing and a lengthy write up, let me know
    Looks very nice
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    damn that thing is tiny! how the hell did you make it that small and 220W? Will it need any active cooling?
    Apr 2001
    Portland OR
    Quote Originally Posted by Scouse Monkey
    If you only use it for 100 watts you don't need a fan or anything. If your going to go over that, a fan is going to be needed. It didn't even get warm powering my 2 gig p4. It was only pulling about 90 watts in idel mode..
    www.mpegbox.com
    Mar 2004
    Bristol
    any plans to fit heatsinks etc etc?
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 12:13 PM
  3. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 05:46 AM
  4. 350 watt power supply
    By MasterJacko96 in forum Power Supplies
    Last Post: 01-20-2004, 04:01 PM
  5. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 05:36 PM
