Results 21 to 30 of 40
Thread: Screw you guys JK
  1. #21
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    hey mike, I am not trying to be puchy, b/c i appreciate your development of this product, but should I wait to buy an p1260 untill after you have made a firmware patch and maybe a "scouse adapter", or should i purchase now and upgrade later...
    do you plan on having a different product such as a "p1260 Socuse" and a p1260 regular or do you plan on selling the same product with an optional upgrade kit and firmware upgrade?
    Whatever the decision, I am first in line....
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
  2. #22
    Jun 2005
    chicago, Illinois
    Quote Originally Posted by RoyN
    Why do all this relay hooking when you can just use the M1's original 12v as a signal lead to the 1260 to go on
    The reason for all the effort is because his 12 line is burnt and unreliable.
    PROGRESS:
  3. #23
    Feb 2005
    S Ohio
    it only has 2A of current that it can provide. The M1-ATX is meant for low power CPU's that run off the 5V line. Power= VoltsX Amps, so 12V X 2 A = 24 watts on the 12 V line. My HDD alone needs 20-30 Watts from the 12 V rail. This solution would use the powerful 5V and 3.3V lines of the M1-ATX and replace the 12V line with a 5A or 60 W 12V rail. the remaining 24 W i would use for my monitor and other small electronics. I have fried my 12V line twice because i thought "i have an 80 watt system and a 90 W psu, I don't care what each line needs." Its funny b/c i knew enough about electronics that I should have recognized
    the M1-ATX ahs enough on the 12V rail for via epias and o few other processors
    and laptop drives run off the 5V line.
    unfortunatley I need a 120 Gb hdd or bigger and i can't buy a 120 GB laptop drive, I'm too poor.
    And i think that the turn on lead is a 5V line?
    My NEW carPC
  4. #24
    Feb 2005
    S Ohio
    hey mike, I am not trying to be pushy, b/c i appreciate your development of this product, but should I wait to buy an p1260 untill after you have made a firmware patch and maybe a "scouse adapter", or should i purchase now and upgrade later...
    Any word, Mike?
    My NEW carPC
  5. #25
    Raw Wave
    Jun 2004
    On the beach
    Mike - the PShare idea is a good one, I saw it on your website but then it disappeared, would be useful.
  6. #26
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by UK_MP3Car
    yeah i remember you showing me that while you were at the meet and I was eating salmon
  7. #27
    Nov 2003
    Marietta, GA
    Any word, Mike?
    Sorry guys. Lots of family stuff going on this weekend. Give me a little while to think it through.
    My preliminary thoughts are as follows:
    1) The simplest solution would be to use the P1260 output BY ITSELF (ie not power combined/shared with the M1-ATX +12V output). You could use the existing P1260 and field upgrade the firmware with a "slave" (..er Scouse) version. This would require you to purchase a $10 PIC programmer and download some freeware. You can see how this works on our website HERE.. It's actually pretty simple. I'll have to dig into the firmware a bit, but I think this could be implemented fairly quickly. So to use the P1260 as a slave you would connect it ignition input to the M1-ATX +12V output. The P1260 would turn on with no delay as soon as the igntion went high, and would turn off as soon as the ignition went low.
    2) Unfortunately, power sharing with the +12V output of the M1-ATX (using PShare) may not work in this scenario. PShare was designed to EQUALLY power share between two of the same type of regulators (ie two P1260's or two P1290's). It controls the slave regulator so that its output current is equal to the master's output current. If the master is an M1-ATX, then it will try to match 2.5 amps. Obviously, this is not what you want to happen. Let me think this thru to see if there is a way to make this work. But I think the simplest way to do this is like you had suggested before: use the M1-ATX to power SOME of your +12V device, and use the P1260 to power the mobo.
    I'll try to make some progress on this early next week. I'll keep you posted.
    MikeH
  8. #28
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by MikeH
    Ok..Ok...we'll call it the "Scouse Adapter"
    Why would you want to adapt anything to allow it to connect to scouse?
  9. #29
    Nov 2003
    Marietta, GA
    ...perhaps a corkscrew...?
    MikeH
  10. #30
    Mar 2004
    Bristol
    excuse me!!!!!
  1. Screw the Screw the old 'so cal meet' Thread!! Date Set 7/16/05
    By 12Vsystems in forum MP3Car Gatherings
    Last Post: 07-25-2005, 12:35 PM
  2. Acura 3.2tl Just Finished Tell Me What You Guys Think
    By Desisolja2 in forum Show off your project
    Last Post: 06-17-2005, 05:47 PM
  3. What do you guys think of this new technology? The DVpod
    By SoloSL203 in forum General Hardware Discussion
    Last Post: 05-06-2005, 02:34 AM
  4. how did you guys anchor your computers in the trunk?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 09-15-2001, 11:30 PM
