Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: Screw you guys JK
  1. #31
  2. #32
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Enforcer
    or maybe a non-digital screw
    let's see who can work that out
    i got it! And I wish i would get it!
  3. #33
  4. #34
    Mar 2004
    Bristol
    You wish to receive
    only off a girl!
  5. #35
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    ok, Im gonna do it. I am gonna run an M1-ATX and a P1260 together.... I am not going to worry about timing issues. They both have a startup delay near 5 seconds, they have customizable shutdown times, I think i'll set the M1-ATX to 45 sec and the p1260 to 90 sec.
    I don't think im gonna fry anything up. I enjoy defying logic.
    Anyway, Im gonna use the p1260 for the 12V line and cut the 12 V from the m1-ATX out and just use it for really small things. So I need people to give me warnings about why i should wait until MikeH comes out with Pshare, or else I'm gonna do it, I'm too impatient
    -drew
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
  6. #36
    Nov 2003
    Marietta, GA
    Moneyfink,
    I've just posted the SLAVE firmware for the P1260 (will also work with P1280, P1290, and P1900). Take a look at the UFlash instruction page for how to upgrade your firmware. Let me know if you find any problems with this functionality.
    The SLAVE firmware gets rid of the turn-on and turn-off delays on the P1260. It monitors the ignition line and will turn on and off immediately as the ignition goes high/low. When using the P1260 as a SLAVE you should use the ACPI control from the master PSU (M1-ATX) to control your mobo. The P1260 still monitors its output current and will shut down after a 10 second delay if you draw more than the specified current (5 amps for the P1260). It also continues to monitor for fan failure and low battery, again, shutting down if the failure condition lasts for more than 10 seconds.
    Good luck!
    MikeH
  7. #37
    Feb 2005
    S Ohio
    you are my hero
    thanks man
    -drew
    My NEW carPC
  8. #38
    Feb 2005
    S Ohio
    I noticed that you have taken down the slave firmware? Is there any reason for this? I have the p1260 and the m1-ATX both in my possesion right now. If you have permanently removed this stuff then i will make it work anyway
    My NEW carPC
  9. #39
    Nov 2003
    Marietta, GA
    Oops! Sorry about that. I'm not sure what happened. I'm out of town until later in the week. I'll try to get it reposted shortly. Do you have a PIC programmer?
    MikeH
  10. #40
    Feb 2005
    S Ohio
    nope.... Right now im just confused as to what wires to cut on my atx connector. the cables that came with the m1-atx cross a little.
    What i mean is that pin 4 on one end connects to pin 6 on the other end
    My NEW carPC
  1. Screw the Screw the old 'so cal meet' Thread!! Date Set 7/16/05
    By 12Vsystems in forum MP3Car Gatherings
    Last Post: 07-25-2005, 12:35 PM
  2. Acura 3.2tl Just Finished Tell Me What You Guys Think
    By Desisolja2 in forum Show off your project
    Last Post: 06-17-2005, 05:47 PM
  3. What do you guys think of this new technology? The DVpod
    By SoloSL203 in forum General Hardware Discussion
    Last Post: 05-06-2005, 02:34 AM
  4. how did you guys anchor your computers in the trunk?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 09-15-2001, 11:30 PM
