sure, it should work fine, however you will probably have to devise some way to make it so the carnetix only comes on when the M1 comes on. obviously leaving it on all the time would be bad, and if it didn't turn on until after the M1, the computer might get unhappy.
LinkBack URL
About LinkBacks
). I'll even mod some firmware so that the P1260/P1290 can be used as a slave (no delays). This way you could hook the P1260 ingition line to the +12V output of the M1-ATX and let it turn ON/OFF the P1260.
