Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Another M1-ATX problem.. Pls help!
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    OK, finished installing my system, and I know it works since I loaded the HD with all my files, using a regular 110AC ATX power supply. After i mounted everything (M1-ATX, VIA SP-1300, Seagate 250GB HD), The M1-ATX powers up the system; The CPU fan turns on, and I can hear the HD spin up. However, I get no VGA output from the motherboard. I have checked this using both my LCD and my desktop CRT. The aux power connectors all check out good (12v, 5v, gnd) I also remember that when I was initially configuring the system, when the system was booted, the board would beep upon entering POST. It doesn't even do this. Is there any way I can check anything else on the M1-ATX?
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    do you have another motherboard to try?
    Sep 2003
    Tampa, Florida
    unfortunately, no.
    WORKLOG
    Webpage
    Mar 2004
    Bristol
    Then try a normal PSU with your mobo. (yeah i am suspecting its your mobo not the PSU - unfortunately)
    May 2005
    Eureka Ca
    i have the same mobo and PSU, i had the same problem twice, what i did was turn the car on for 10 min then tried it again and it worked. I thought me battery might of had a low charge ? not sure if that was the fix but it worked.
    PS, i only used the car computer for week so far.
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by malkalm
    huh, odd. My next troubleshooting step is to rip my power supply out of this computer, and test it out in the car. I did try restarting it with the car on, and it didn't make a difference.
    WORKLOG
    Webpage
    Mar 2004
    Bristol
    dude, jcdillin just pointed out post 26 in your install thread where you have the pink foam/bubble wrap on the back of your mobo. THIS IS ANTISTATIC AND THEREFORE CONDUCTIVE! so you have likely fried your mobo as I thought.
    sorry to be the one to break it to you.
    Mar 2004
    Bristol
    Oh and your M1 ATX is on white foam which is probably conductive too if it is what some electronics came packed with!
    Sep 2003
    Tampa, Florida
    I thought that stuff was not conductive, and was just for shipping cushioning since the board was shipped in an antistatic bag. Crap, I hope I didnt permanently screw anything up. (crosses fingers)
    WORKLOG
    Webpage
    Mar 2004
    Bristol
    Pray, pray all night!
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  2. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  3. ATX Pin problem
    By BiohazrD in forum Power Supplies
    Last Post: 05-18-2005, 10:05 PM
  4. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 11:06 AM
  5. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
