Damn good idea. Nice connectors.
:cough: http://www.mp3car.com/vbulletin/show...38&postcount=6
Don't just take JCDillins reccomendation - they are very very good. I used em on RC cars that destroyed just about any other connector
For all of you that are wanting a way that you can create a high amperage disconnect for your DC-DC power supplies. I just redid my power supply lines with these powerpole connectors from anderson. They are great, I purchased the 45amp versions but you can get much higher amperage if you need.
I bought mine directly from anderson
you can find them here
now for some pictures of them
as you can see they slide together so you can make custom connectors, I used them to make the 5v and 12v connections diffrent in my dash so I dont plug something in the wrong way
here are my 2 opuses connected up with these connectors
So for anyone that’s looking for a great alternative to crimp connectors I highly recommend these
oh yeah and thanks to scouse for turning me on to these![]()
肚子笑痛了
S60 Install
I knew it was in there, but it was buried deep in a thread, it neds to be out here in the open!! and we needed pictures of them in action![]()
肚子笑痛了
S60 Install
Is there a UK supplier?
Well you might check fleabay, because I was able to get a 2nd batch from there for about the same price
肚子笑痛了
S60 Install
Radio spares and Model shops (but both will not be the cheapest around). Might wanna check CPC/Farnell and Rapid electronics. Or jsut give Anderson a bell and fnd out.Originally Posted by UK_MP3Car
http://www.powerwerx.com also sells them.
I use these at work with a RigRunner as a bench test rig. Good stuff!
IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
Very cool!
Do any of you know if anyone makes a through-case version of these? I'd like to have my power supply connectors plug into the case, rather than via loose wires....
(By through-case, I mean that the connector mounts to the case using screws, then the opposite connector is joined via a hole in the case.)
If you look at the manufacturers site you will see various mounting options - one be the type of thing you are looking for.
There is also a semi-circle on each connector that forms a full circle for mounting and locking the connectors together.
