Results 1 to 10 of 10
Thread: OPUS shuttle casing removal?
    Jun 2005
    Kent, England
    OPUS casing removal?
    if i got the cased version of the opus can i remove the outer casing and mount with just a backing plate or something?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I don't see why not.....just use raisers to mount it in the case.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    ill give you $8 shipped for that casing
    PC Components:
    My work log
    Jun 2005
    Kent, England
    thanks
    @peoples whoa...slow down! i have got it yet lol
    and unfortunately it'll probably cost more than 8$ to get it from the UK to the US
    Dec 2004
    Maryland
    ohh, didnt notice your in the UK
    PC Components:
    My work log
    Apr 2005
    no you can't ...
    The shuttle version casing for the OPUS 150 is made of aluminum and it is there for a reason. It is there to dissipate heat and it does not simply just come off the risers. On the underside of the board there is a heat sink BRIDGE that attaches the board to the shuttle casing. If you took the Shuttle opus PCB off its aluminum shell it would overheat. You would need to get a fan to prevent this from happening. If your going to do that your better off just buying the regular opus 150 in the larger steel casing with a fan already incorporated and manipulating that.
    CL
    Jun 2005
    Kent, England
    sorry i got it wrong. it was a standard cased opus and not a shuttle
    thanks though
    Apr 2005
    ahh ... just make sure you take the fan where ever you put the opus board.
    You also might want to look into if the shuttle casing will fit your install. It will save you having to worry about cooling and you could probably buy it from opus for 20 dollars or something.
    Jun 2005
    Kent, England
    my pc won't be mounted in a case as such. all the components are to be mounted separately on MDf stealthed away
    the power supply is on its way now and i'll probably take the case off when i mount it
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    I took it off, I made my own case and mounted just the board behind the mobo
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. Can Shuttle SN41G2 be used without special Opus?
    By Anees in forum Power Supplies
    Last Post: 06-06-2005, 11:45 AM
  3. OPUS 150 SFX Fan or XPC Fanless Casing Option
    By lostreception in forum Power Supplies
    Last Post: 05-27-2005, 04:39 PM
  4. OPUS in a shuttle mini atx?
    By Slitha in forum Power Supplies
    Last Post: 09-24-2004, 08:20 AM
  5. Opus 150 watt psu and Shuttle st62k
    By ryanreko in forum Power Supplies
    Last Post: 04-15-2004, 01:17 AM
