Results 1 to 10 of 13
Thread: Lilliput powered from Cig. Lighter?
    May 2005
    I had planned on powering my Lilliput via the power wires from the lighter in my car by splicing the supllied Cig. Lighter adapter. After reading a few posts, there seems to be problems with this, correct? The suggested way is to use an Opus PS. Im not going to do that because I have a laptop and Im not going to buy one since im not going to use it w/ said laptop. So what would be the best way to power the screen if I cant directly wire it to the lighter through the adapter.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    search!!!......the egg is notorious for failure....and giving your lilliput an unregulated power feed will try it (not designed for that)....power it with another regulated power supply
    PC Components:
    My work log
    May 2005
    I did search, most post refer to the opus or schematics on building a regulator. Since I dont want to do either what is a regulator suitable for the application.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Top of the LCD section..... Powering your LCD Monitor
    May 2005
    Ive read that... In it is suggestions for running it off of OPUS, off of the computer, and schematics for building regulators. Since I said Im not doing any of those, once again what is a regulator I can buy....
    Mar 2004
    Bristol
    Quote Originally Posted by flaVius
    oh for ***** sake. You didnt read it at all. Why do i bother?
    Read my post - #4 - and the last 2 paragraphs talk about using an alternative DC-DC regulator!
    May 2005
    I did read it and I dont think that a portable dvd regulator or the like is any better suited than the adapter than came with my lilliput.
    Mar 2004
    Bristol
    Read People's reply above
    and then what i wrote. Try the egg - if you notice any problems get rid of it. the newer eggs might be better but the old ones were crap.
    READ!
    May 2005
    WTF, I did read it. Youre the one that needs to learn how to read. I asked how to do this since its suggested not to use the egg. Why would I want to use something that is notorious for failure.
    Mar 2004
    Bristol
    ARGHHHH I give up!
    soembody please take over.
  1. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  2. Powered lilliput makes speaker scratches...
    By cyrix^ in forum Input Devices
    Last Post: 05-11-2005, 06:41 AM
  3. Wiring monitor/psu with cig lighter?
    By kendire12b in forum Power Supplies
    Last Post: 11-08-2004, 11:27 AM
  4. HardWire Lilliput to back of Cigarette Lighter
    By eazyrog in forum LCD/Display
    Last Post: 05-24-2004, 06:51 AM
  5. 600watt inverter off Cig lighter?
    By lstrunk in forum General Hardware Discussion
    Last Post: 12-29-2002, 01:10 AM
