Results 1 to 3 of 3
Thread: relay grounding question
    Jul 2005
    For this circuit, what gauge wire should i use for the ground? In other words am I trying to ground the remote turn on lead or the 12V+ from the battery?
    Variable Bitrate numbers's Avatar
    May 2005
    You are grounding the remote turn on lead. What size you use is almost insignificant. Hardly any current will be flowing through it. Just use the same size as the existing remote lead and you won't have anything to worry about.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    You would ground after each of the components off 30. The wire would need to be sized according to the draw of the component. As numbers said, remotes for amps use almost nothing. What you term "Fan 1", "Fan 2", and "Additional Accessories" would need wires according to their current draw.
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  1. Electronics Question - Parallel Relay
    By blazinlow in forum General Hardware Discussion
    Last Post: 11-07-2004, 01:39 PM
  2. Replies: 13
    Last Post: 09-20-2004, 07:01 PM
  3. 12V relay + diode question
    By cybermob2 in forum Power Supplies
    Last Post: 05-18-2004, 01:11 PM
  4. Relay question
    By lopan in forum Power Supplies
    Last Post: 02-25-2004, 10:17 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
