Results 1 to 6 of 6
Thread: M1-ATX /w SP 13000 mobo
    Mar 2004
    Hey there,
    I've been running my new M1-ATX and Epia SP13000 successfully for a couple of weeks now. I have a question related to current draw...
    My M1 currently powers a samsung 80gb 2.5" HD, and the SP 1300 -- I am running my Lilliput and USB hub in the front of the car with two separate regulators.
    The Lilliput is using the stock 12V regulator and the USB hub is hooked up to something I picked up off the net. The monitor runs pretty well, I never notice any screen dimming whatsoever, save for when my signal light is on.
    The USB hub is giving me problems however. At first I thought it was the USB connection so I changed cables and I still get random disconnects. It's running my Tripnav GPS and Lilliput touchscreen and at times they just stop working. Unplugging and plugging it back in sometimes works however not all the time.
    I believe that this is because the 5vd regulator I have cannot provide enough current to the USB hub. So I am considering running a 4 conductor line from my trunk up to the front to power my Lilliput and the USB hub. My question is: will I burn out the M1-ATX?
    I've looked on mini-box's site and they don't list the SP13000's current draw. I'm scared that I'll blow something on the M1, and I don't want that!
    Again to recap: the M1 will run the SP1300 mobo, samsung 2.5" 80gb drive, USB hub, and the Lilliput 7" monitor.
    Any thoughts?
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I don't think you're going to have problems powering your hub from M1 at all
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Low Bitrate ALonDonThinG's Avatar
    Aug 2004
    London
    My M1 powers an sp1300-lilliput-slimdvdrom-USB hub with 4 ports-Digitaltv-gps mouse-
    full size hd-wireless adaptor-Audigy pci soundcard.
    you should be fine.
    Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Why not utilize the other 6 usb header ports instead of stretching one of them with a hub?
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Nov 2004
    Italy
    I think because the mainboard is in the back of the car and he wants multiple USB headers in front
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Mar 2004
    Quote Originally Posted by Frankino
    Yup. And my Ampie doesn't provide extra room for the ports. It's OK though, I have no use for them.
    1997 Acura 1.6 EL
    Ampie Case, Epia SP13000, 1G ram, 80g 2.5" HDD, Tripnav GPS, Lilliput 7" Touchscreen, M1-ATX
  1. How to use a standard atx ps on a compaq mobo
    By tastyratz in forum Power Supplies
    Last Post: 01-07-2010, 09:02 AM
  2. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  3. full ATX mobo and req. power
    By fishy in forum Power Supplies
    Last Post: 10-13-2004, 01:53 AM
  4. $200 DC-DC ATX PSU + CASE + MOBO + C3 800mhz CPU
    By moahdib in forum Power Supplies
    Last Post: 05-20-2002, 09:50 AM
  5. ATX mobo users how did you hook up power on switch?
    By BeigeMaxima in forum General Hardware Discussion
    Last Post: 06-25-2001, 09:00 PM
