Results 1 to 7 of 7
Thread: Quick Question: Would it be bad to plug my inverter on same wire as my amplifier?
    Low Bitrate wardemon666's Avatar
    Jun 2005
    I have 4aug wire going directly from the batt down to the trunk. I am planning on using the same wire for powering my inverter. Its 2-4aug, and my amp is 800 watts max, 425 rms, inverter is 325 watts continuous...
    Would it cause problems if i connect everything on the same wire? Would my puter survive crank? (it survived crank when i plugged it directly on the battery)
    Thanks,
    Carl
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    personally i have no problem with my setup
    10ga batt to amp (210 watt)
    spliced off both ground and Pos to inverter so far so good
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Jul 2004
    I don't know that I would splice off but rather run/use a distro block. for both the power and ground. In my case, I ran power and ground straight to the inverter with an inline fuse there. I then ran another set of cables from the inverter to the amp with its own connectors.
    http://memimage.cardomain.net/member_images/2/web/170000-170999/170063_221.jpg
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    shouldnt cause a problem. I have a 4ga powering my inverter and 4 other things and i survive it.
    Registered User Nicorolla's Avatar
    NB,Canada
    it will not cause any problem if installed right
    for reference check the wire section of www.bcae1.com
    Apr 2005
    NJ
    given that is only temporary install until I get 2nd amp and glass everything... no point in buying all the stuff now before I can start wiring it right
    Hello! VW Golf 1.8t
    May 2005
    Ottawa, Canada
    It will not be a problem power-wise, but some cheaper amps will let some of the electrical noise that the inverter generates into the audio signal. This was the case for the small rockford fosgate Punch 150s that I use for my center channel. A ground loop isolator fixed the problem. My Zaco AG650 was not affected at all.
    Sentra CarPuter:
    -InnovaTek 7" LCD touchscreen, Biostar M7VIZ w/ AMD Athlon XP-M @800 MHz 1.1V, 512 RAM, 160G HDD, M-Audio Revolution 5.1, USB Wi-Fi with custom external antenna, Holux GPS and lots of really nice audio bits...
  1. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 03:20 PM
  2. Question on using a relay for powering PC using remote wire
    By mattress in forum General Hardware Discussion
    Last Post: 02-07-2005, 09:19 PM
  3. Power inverter on/off switch question
    By Skipjacks in forum Power Supplies
    Last Post: 01-22-2005, 01:33 PM
  4. question about inverter
    By Magsino in forum Power Supplies
    Last Post: 08-13-2004, 10:09 AM
  5. How bad exactly is an inverter?
    By SpeedFreak03 in forum Newbie
    Last Post: 06-18-2004, 04:30 PM
