Search on terms "DIY shutdown" or "DIY". You'll find lots of threads on the topic.
Hello, I'm new on that board, but I've been reading post here for last 2-3 weeks and now my carputer projet is starting. Onlyproblem is that I have a concern about powering the computer.
First of all, I live in canada so shipping cost is an issus...
Computer gonna use a normal ATX PSU running on 120 VAC, as for the car I'll use an inverter. Only problem is to powerup those thing and the biggest problem is to poweroff them... I was thinking about a relay that would be on the 12V line that goes to the ivnerter and an other relay between the power switch pin from the mobo (and a delay device between those two action (didn't figured it yet just read Delay device)
As for the shutting down device, I just don't have any idea, any help would be really apreciated
Want to:
What you guys think about that shematic would it work ?
How2 control CarPC from key fob....
take a look at this
Schematics/Pin Outs/Diagrams
thk a lot, that's a really simple way and is damn good ! now I just need a mobo with two serial port so I can plus my button interface also ! thk !
Ghetto Startup/Shutdown Control for Inverter
That is what I did
my god that is brilliant.Originally Posted by Nicorolla
Now, if you wanna go the Car pC route, this is the right forum for you. You can surf gay porn, listen to all your copywright infringed music and use GPS to find your way from one end of the driveway to the other -J187
I posted some stuff about the shutdown controller i built for my car here:
DIY Shutdown Controller
It's based on a PICAXE microcontroller, which is relatively easy to code for and program compared to other stuff out there, but it's probably overkill for most people. Probably easier to buy one from the mp3car store if you live in North America.
