Results 1 to 10 of 16
Thread: Can a Carnetix CNX-P1290 90W power these three?
    Low Bitrate markuskj's Avatar
    Jun 2005
    Abdn, Sco.
    I know this powers 2 devices, but can it be rigged up to power 3?
    1: Lilliput 7" screen
    2: Via Epi mobo
    3: 4 device USB powered hub?
    I want them to all trun on together you see?
    Thanks in advance!
    Mark
    Ice: Nakamichi MB100, Dynaudio 340, Genesis Dual Mono, JL 12w2, Epic 160
    Current Project: Fitting a Cologne V6 to an Eagle SS
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    Yes it can.
    Use the 12V feed from the carnetix to power your screen and a suitable DC-DC ATX powerboard for the Epia motherboard.
    Then use the 5V feed for your USB powered hub.
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
    Jun 2005
    Abdn, Sco.
    Thanks for this - I have a "12V 200W Epia MII "Plug In" Power Supply Board" on its way. Sorry for a moronic question but if the carnetix supplies power to the plug in board (via the female round power connector) does this not mean that the 12v line is already taken?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Just tap into the 12 volt outputs before you wire them to your power supply.
    Want to:
    Mar 2001
    Easily. The Carnetix rocks and Mike provides GREAT support.
    Check out my carputers:
    DVD, GPS, MP3, 6.4" LCD Touchscreen, 5" Headrest LCDs, PSone, DSSC, etc.
    Jun 2005
    Abdn, Sco.
    Quote Originally Posted by Bugbyte
    Perfect - thanks. I hoped that this was the solution but just wanted to check before screwing it up
    Jun 2005
    Abdn, Sco.
    Quote Originally Posted by bergeron76
    Mike?
    Nov 2003
    Marietta, GA
    Yes?
    MikeH
    Jun 2005
    Abdn, Sco.
    Quote Originally Posted by MikeH
    Yes?
    LOL - Sorry Mike, did not mean to make this sound like a summons, I did not know that you posted on here so was wondering who Mike was!
    Since I have your attention, Iam happy with the solution above to run the mobo and screen from the 12 v supply,and the usb hum from the 5v, but is there a way to also run another 4 way usb hub from the system or is this overload?
    I am just about to install the device in the car, I assume there is a pass through remote turn on cable for amps?
    Mark
    Nov 2003
    Marietta, GA
    markuskj,
    As I'm sure you know, hubs don't draw much current....However, USB Devices CONNECTED to hubs can potentially draw lots of current... So the answer to your question is...it depends. What devices will you be powering? The total current available on the +5V output form the P1290 is 3 amps. This will easily power many small USB devices like keyboards, mice, GPS receivers, as well as a few larger devices. Power hungry devices like USB sound cards (ie Audigy 2NX), USB video cards, and some USBS WiFi devices can potentially draw quite a bit of current. You'll need to do a bit of homework on your specific config to see if you're within the 3 amps limit. If not, you can always add the CNX-P5V. It gives you another +5V/3amp output, doubling the +5V power available.
    I've posted some examples of my system devices HERE. The Audigy 2NX draws about .8 amps.
    There is a "remote" trigger for your amps called DLYON (delay ON) which has a 3 second delay before it enables your amps. This helps prevent speaker "thump".
    You may want download the Installation Manual from HERE.
    I hope this helps!
    MikeH
  1. 90w Opus won't power up. Also - where is the LED?
    By Febs in forum Power Supplies
    Last Post: 04-21-2006, 01:05 PM
  2. carnetix 1290 + commell 671 weird supply probs - help !!!
    By satmanuk in forum Power Supplies
    Last Post: 07-11-2005, 09:57 AM
  3. Does CNX 140W PSU support standby/hibernate as OPUS 150W PSU does?
    By baboojoon in forum General Hardware Discussion
    Last Post: 07-07-2005, 11:27 PM
  4. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 12:08 AM
  5. Can Opus 90w power these?
    By harrisonpowers in forum Newbie
    Last Post: 11-25-2004, 09:28 PM
