Results 1 to 10 of 19
Thread: M1 to power....
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    M1 to power....
    Hi,
    I've my carputer ready to fit, consisting of :
    Intel P3 833MHz motherboard, not sure what make
    Seagate 7200rpm 40 gig
    264MB RAM
    DVD/CD-RW drive
    Tiny processor fan and 13cm case fan
    Would the M1-ATX 90w be enough to power this load in car?
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    the DVD may be a problem, go for an external USB device with external power source if possible
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Apr 2005
    Ireland
    It'll be used on...super rare occasions lol. How much power then to run it?
    Apr 2005
    Ireland
    Nov 2004
    Italy
    ho, it's only a regulator, you also need a power supply to run your pc
    M1 atx will easily be overloaded powering a standard HDD and DVD, it will be overloaded if you also run your LCD
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    where did you find 264 mb of ram?
    Anyway, a M1-ATX has 90 W, but you can't just look at what you are powering and say OH, I need 70 Watts so I'll be fine. That is wrong. If you look at the specs, each line has a maximum Amperage that it can carry. http://www.mp3car.com/products/M1-ATX/M1-ATX-specs.pdf
    So what I'm saying is there are 3 lines that I will talk about the 12V, 5V, and the 3.3V line.
    First you should know voltage times aperage = Watts (power)
    The 12V line can do 2 Amps= 24 Watts (a single 7200 RPM HD can demand up to 30 Watts!!!(Thats only a peak measurement tho(yay for parenthetical expressions!!!)))
    5V line has 10 A = 50 watts
    and 3.3 V outputs 10 Amps = 33 watts
    So actually if you add that up you get 107 watts of power. But you can also see that if you want to run a CPU and A motherboard that primarily ge their power from the 12V line you are screwed. mini-box even says that this is designed for low power systems that are powered off of the 5V line.
    Check out this website: http://www.ohmygodmyarmfelloff.com/MP3Car/PSUpower.asp
    for the rail breakdown of whatever system you are trying to set up.
    BTW an LCD is about 6-7 Watts (i think) all of it on the 12 V line so that will add a .5 Amp draw on you power supply.
    I learned all of this the hard way after burning up 2 m1-Atx. Now I'm modding a M!-ATX and Carnetix P1260 to work together so i can have a big 12 V line
    Anyway good luck and let me know if you have more questions?
    Should I turn this post into a FAQ?
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    Apr 2005
    Ireland
    Just gop with the OPUS?
    Feb 2005
    S Ohio
    opus is definitly easier to setup. I am poor so i went with the m1-atx, but in the end i only saved a few pennies. the common theory is that you end up buying the opus so you might as well buy it first and save yourself the frustration
    My NEW carPC
    Apr 2005
    Ireland
    Bugger that. Maplin has a 300w inverter on special offer for 32...! Just keep the original P/S....!
    Nov 2004
    Italy
    Quote Originally Posted by Moneyfink
    opus is definitly easier to setup. I am poor so i went this way, but in the end i only saved a few pennies. the common theory is that you end up buying the opus in the end so you might as well buy it first and save yourself the frustration
    couldn't agree more, tested myself
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 03:39 PM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
