Results 1 to 10 of 20
Thread: Square wave inverter
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Will this sound odd like a modded sine wave?
    L
    Variable Bitrate numbers's Avatar
    May 2005
    Could you repeat the question? If you're asking whether an inverter outputting a square wave will have the same negative effects as the modified sine wave produced by your average inverter, then the answer is yes. A handfull of things will actually run more efficiently, a bigger handfull will not work at all, and most will suffer reduced performance and efficiency.
    Apr 2005
    Ireland
    What effect will it have on the sound though? if all units are grounded to a common point
    Apr 2005
    Ireland
    Will a computer PSU work? I see no reason why it shouldn't.
    L
    May 2005
    What do you plan to power with it?
    May 2005
    I wouldn't expect it to run particularly well. It may not run at all. A modded square wave would be fine, but not a true square wave. Did you get an old square wave inverter as a freebie or something? They're not exactly popular these days...
    Apr 2005
    Ireland
    From Maplin, ah heck, they're good with refunds.
    a 200 watt power supply.
    http://www.caraudiodirect.co.uk/prod...43867161339a3c
    Apr 2005
    Ireland
    Apr 2005
    Ireland
    For all I know the guy at the shop could know nada and it is probably a modded square wave...and if it isn;t and doesn't work, I'll just ground everything, RCAs...the lot
    May 2005
    The faq says that is a modded sine wave inverter. (modded square - modded sine - same thing) Technically I think it should be called modded square as it looks nothing like sine.
    Now - is it sound interference that you have been worried about here? I just want to be clear. The wave type of the inverter has little to do with any interferece coming out the speakers. No amount of grounding will affect whether something works with one kind or another. The kind of effect that the wave type has is whether something works at all, how well it works, and how efficiently it works.
  1. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 02:20 PM
  2. Replies: 3
    Last Post: 10-18-2004, 01:14 AM
  3. Speakers using a modified sine wave inverter
    By frostband in forum Power Supplies
    Last Post: 05-18-2004, 12:41 PM
  4. Speakers using a modified sine wave inverter
    By frostband in forum Car Audio
    Last Post: 05-04-2004, 04:53 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
