Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: m1 atx 90watt...is it for me?
  1. #11
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    I should think it will be fine as it is your only 12V device.
    Best advice would be to try it and see. If you have problems pick up a cheap laptop drive but I doubt you will.
    People have run more demanding systems on an M1 so give it a go.
  2. #12
    Constant Bitrate Power_nisse's Avatar
    May 2004
    Sweden
    ok, better feedback in this thread. gonna orders soon and i dont know if my M1 is sufficient.. Take a look please =)
    Im gonna get the ampie case, thats it but after reading in this thread i dont know if the M1 ATX is sufficent.
    I will connect following
    VIA EPIA SP13000, m/Via C3 CPU 1300MHz Mini-ITX,DDR400,VGA,Tv-Out, Firewire
    Crucial PC2100 DDR-DIMM 512MB CL2.5. Non-parity, 2.5V, 64Meg x 64
    SATA - Samsung SpinPoint M40S 80GB 5400RPM SATA2 2,5" 9,5mm
    IDE - Pioneer Slot Load DVD±R/+R DL/±RW Dual Drive 8X "Slimline"
    USB - A 7 Avator 7 tft Touchscreen, screen and usb connected
    USB - 3COM OFFICECONNECT 11G 108MBPS WIRELESS WLAN
    USB - GPS, The gps has batteri but recharges via usb.
    USB - Remote controll later on
    according to power guides its near the edge hehe but the slimline DVD writer is the only 12 V. And most of the USB gadjets uses only a few hundred milli ampere
    What do you think..
  3. #13
    Mar 2004
    Bristol
    Should be fine. (but same again - weigh up the cost for the extra 30W out of the opus 120 compared to postage etc)
  4. #14
    Aug 2005
    Ueee paesà... stò lavorando ad un PSU che non sia fatto con i soliti integrati della Maxim, utilizza infatti un comunissimo sg3524, funziona molto bene e riesco ad ottenere un rendimento medio vicino al 85% ma il problema è che utilizza delle ferriti da ampli car, difficili da trovare, stò sperimentando con delle ferriti prese da alimentatori PC... è un pò più complicato (lavorano ad una frequenza + alta) ma almeno le ferriti si possono trovare agggrrratis, basta andare in qualsiasi centro di raccolta rifiuti e gli alimentatori da PC te li tirano dietro.
    Penso in un paio di settimane dovrei riuscire (se mi arriva l' oscilloscopio che ho in riparazione) a testare e postare uno schema definitivo, magari con lo stampato bello da stirare (metodo stira ed ammira) come da esempio che trovi qui: http://www.baronerosso.net/mod-subje...ageid-167.html
    Per ulteriori info puoi contattarmi all' indirizzo: [email protected]
    Dice il saggio:
    Due cose sono infinite, l' universo e la stupidità umana...... e non sono sicuro della prima. (A.Einstein)
  5. #15
    Mar 2004
    Bristol
    eh?
  6. #16
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    He said (according to altavista bablefish)
    Paesà Ueee... stò working to a PSU that is not made with the integrated usuals of the Maxim, uses in fact the most common one sg3524, it works very well and I succeed to close obtain a medium rendering to 85% but the problem is that it uses of ferrites from widens car, difficult to find, stò experimenting with of ferrites taken from locals p0wer source PC... is a complicated Pò more (works to a high frequency +) but at least the ferrites can be found agggrrratis, enough to go in whichever center of collection refusals and the locals p0wer source from PC you pull them behind. Task in a pair of weeks I would have to succeed (if the oscilloscope arrives me that I have in repair) to test and to mail a definitive outline, with the beautiful print to even iron (method it irons and it admires) like from example that it finds here: http://www.baronerosso.net/mod-subj... pageid-167.html For ulterior info you can contact me to the address: [email protected] It says the test: Two things are infinite, the universe and the human stupidity...... and is not sure of before. (A.Einstein) Rinox is offline Report Bad Post Reply With Quotas
  7. #17
    Mar 2004
    Bristol
    I reiterate: eh?
  1. How to use a standard atx ps on a compaq mobo
    By tastyratz in forum Power Supplies
    Last Post: 01-07-2010, 09:02 AM
  2. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  3. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 04:28 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
  5. ATX to AT conversion?
    By drew in forum General Hardware Discussion
    Last Post: 10-27-1999, 02:28 AM
