Results 1 to 10 of 17
Thread: m1 atx 90watt...is it for me?
    Jul 2005
    Hi,
    I'm a newbie I post from Italy...
    I have a problem with a power supply, I would you like to know if the power supply "m1 atx" is good for my hardware:
    -pentium3 800 Mhz
    -256 Mb pci133
    -HD 2.5" 40 Gb
    -DVD rom 16x
    -mouse gps usb
    -video and sound integrated
    Can I use this Dc-Dc??
    Thanks and sorry for my english....
    Jul 2004
    We!!!
    Ciao!! Compaesano!!!
    Io sono di Verona e tu? Ti lascio il mio contatto msn: mgcomp@passport.com
    M1 atx 90W dovrebbe bastare per il tuo hardware, al max ci alimenti solo la scheda madre e il resto lo alimenti con degli stabilizzatori da 5v e 12v.
    Ciao!!!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yup. it's fine.
    Jul 2005
    Eh...
    Ciao compaesà, io sono di Roma...dici che basta? come faccio ad alimentare il resto con gli stabilizzatori?!?
    E se per il dvd usassi un'altro ali tipo il pw70a con itps? Si può fare?
    Ti lascio la mia email: psyco82@yahoo.it
    Ciao.
    Jul 2005
    Quote Originally Posted by Scouse Monkey
    yup. it's fine.
    Mar 2004
    Bristol
    Quote Originally Posted by psycos
    YES!
    M1-ATX = OK!
    Jul 2005
    YES!
    M1-ATX = OK!
    ok thanks, but if I use a dvd rom for pc (5.25"), is it ok?
    Mar 2004
    Bristol
    I knew you were going to ask that.
    it should be because you are using a laptop HDD. If you get any problems that would be my 1st thin to try unplugging. You could always go with an opus 120 but the M1 should be enough.
    Variable Bitrate intuitionsys's Avatar
    Jul 2005
    Ottawa, ON, Canada
    I haven't tried it with that exact combo but yeah the M1-ATX has given out on me trying to use a full-size CDROM and HD. Mind you I've also got two PCI cards on it (MII-12000 with dual riser).
    Jul 2005
    Quote Originally Posted by intuitionsys
    I think that I must use another power supplies for the dvdrom...
    Another solution is the Opus but here, in Italy, it is very expensive!!!
  1. How to use a standard atx ps on a compaq mobo
    By tastyratz in forum Power Supplies
    Last Post: 01-07-2010, 09:02 AM
  2. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  3. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 04:28 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
  5. ATX to AT conversion?
    By drew in forum General Hardware Discussion
    Last Post: 10-27-1999, 02:28 AM
