THIS ISN'T AOL CAN YOU PLEASE TYPE LIKE A NORMAL PERSON.Originally Posted by Porgieanne316
Hey every one i have a 300 watt invertor in my car i was thinking , Perhaps i could Ground the the wire to the body, then take the hot wire and run it to the direct to battery and i could have a switch drilled into my dash so i could controll the power from there instead of reaching under my seat to do it. And on the hot wire, run that new power switch aswell as a fuse on the wire even though the inverter already has one. Is it possible to have the xbox and my inverter all come one through one switch in my dash instead of having to switch my dash switch on and my xbox? and be able to have it stay on during cranking, I was wondering If i did the connect is it a good method and will my device connected to my invertor still stay on if i turn the car on and off, unlike the cigarette adapter switch. Any adivce would be great, if there a better way to do it so the inverter will constalnly remain on unless I turn if off plesae let me know.
Porgieanne316@aol.com
ALso, I have a Pioneer TV(dash), 2 head rest Tv's, (Perhaps this inverter), I am getting a Tranny Cooler with the fan, and i have a remote start. Any electrical system Mods i should make to accomdate all of this. Is a Gel Battery (Optima) needed. I DO NOT HAVE ANY amps. ANY HELP Is welcomed thanks in advance.
LinkBack URL
About LinkBacks
