10 awg wire from the battery to the opus should be fine, if your just connecting the opus to it.
I bought an Opus 90W used and have no manual, I have read the FAQ but still have a couple of questions.
The input harness that is with the Opus doesn't seem to have aprticularly meaty wire on it, am I ok to connect to this with my power connector (10AWG from the battery)? Should I shorten it as much as possible (they are about 9").
I will only be going a couple of feet from my battery by the way.
To connect the power connector is it obvious where it connects to the Opus? I guess it will be but haven't checked yet.
Chris.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
So the 6" or so of thinner wire is no problem on the connector for the Opus? Doesn't seem like I have much choice anyway I guess.
