sounds like an issue with the motherboard pins
I have the Opus 150 psu, i have everything conected inside the car (12v, ground,ignition).
The problem is that the Opus acts like having no automatic shutdown, when i turn on the Key the computer doesnt boot and when its on it doesnt shutdown when i turn off the car.
The ignition wire i use is the same as my Headunit use(and it works fine with it).
Does anyone experienced anything like this ???
The only thing that helps is that if i double click my mouse the computer turn on , but the shutdown must be manual![]()
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
PC Components:
My work log
Have you checked the DIP header settings to make sure you have selected shutdown mode.![]()
Make sure the white\green wire is hooked up to the mobo correctly.
I thought that all opus 150 had that setting as default...Originally Posted by Enforcer
How can i know the settings, opus came without instructions or manual....
I had a PDF file, but i cant seem to find it![]()
"Make sure the white\green wire is hooked up to the mobo correctly."
I dont have it conected to the motherboard right now because if i do that i can not start the computer with the double click on the mouse....
Thanks for the quick answers
If that white\green cable is not connected it is normal that it doesn't shutdown,that is the cable that signal the mobo to shutdown the pc.
i have the pdf manual tried to upload it in a zip file but max is 200kb and this zip is 201kb so if you want it i could mail it to you
I know that, but it didnt work with wire conected to the motherboard either, so in order to start the computer by double taping the mouse buton i had to disconect the green/white from the motherboard....Originally Posted by 00christian00
When i try to activate the automatica shutdown/startup i always conect the wire to the mobo.
ste1806 - You got Pm
try the green / white cable the other way round, its the wrong way round it wont do anything.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
http://mvaras.workisboring.com/serve...r%20Manual.pdf
Thats the Opus 150 manual
