Results 11 to 20 of 23
Thread: Help! Configuring M1-ATX
  1. #11
    Variable Bitrate looneeii's Avatar
    Feb 2005
    Gatineau, QC, Canada
    really?
    99 Grand Prix Grand Tigress
    HW
    Liliput 8in TS
    845GVD MITX w/ 2.4 Mobile P4M (478 MB)
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
  2. #12
    Low Bitrate agentloveless's Avatar
    Aug 2005
    So Cal
    straight from the manual
    Controls and Settings
    J2 Controls amplifier via remote ON/OFF. Left pin is RMT, Right pin is GND
    J6 To motherboard ON/OFF switch
    J7 User jumper settings (A,B,C,D)
    J8 To external ON/OFF switch (optional, J8 is in parallel with J6)
  3. #13
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by looneeii
    Nice pick Zeb, the only thing is I wonder is did you just splice into the 3 cables?
    I just spliced into the 12 volt battery source and the wire to car's ignition switch. The M1-ATX ign wire terminates at the switch.
    Has anyone tried what agentloveless found? It would be great if it can manually keep the system up but I wonder if it can also keep the system from turning on. That is a feature I sometimes need when I am driving a very short distance such as drive out of the garage to the driveway to wash the car or other simillar situations.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  4. #14
    Oct 2005
    Sydney, Australia
    Quote Originally Posted by Zebelkhan
    I have a simple toggle ON-OFF-ON switch connected as in the diagram and it is working fine:
    Edit: Looks like I messed up in naming the poles. Diagram shows location of A, B and C reversed but it does not matter as long as it is connected as shown. In here,
    A - Carputer starts and shuts down as designed whenever car is on or off
    C- Carputer never turns on
    B- Carputer is turned on and stays on even if car is turned off.
    When you change from one side to the other, if your middle pole is a dead wire, doesn't it trigger a shutdown on the M1-ATX?
    So if your system is powered by the ign wire from your car, and before you turned the car off you flick it over to be powered from the 12v +ve, doesn't it switch off?
    I have tried to use J8 switching it, but i found that you need to turn the switch on and off a number of times to get it to start the system when the Ign is turned off.
    Dan
  5. #15
    May 2004
    Denver
    Silvo - it takes 5 seconds of "off" before the P/S responds... so you can even turn the car completely off and then flip the switch and it will still stay on...
    J8 should boot the system, but this is just a momentary connection... I don't use this connection currently, but when I need to boot my system, I just short the J8 jumper with a car key... and if I need to reboot the system while the car is running I can short J8 for a few seconds and it will shut down immediately...
    does that answer your questions?
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
  6. #16
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by Silvo
    Dan
    mgithens is right. The change has to continue for 5 uninterupted seconds before the board boots or shuts down. I wonder if the same thing is reasoin why you say "you need to turn the switch on and off a number of times to get it to start the system when the Ign is turned off." Maybe if you push it and leave it alone for 5 seconds it will start? Just a thought...
  7. #17
    Oct 2005
    Sydney, Australia
    mgithens - yes it does answer my questions. Time for me to install a switch on my M1. Thank you.
    Zebelkhan - This switch will replace the need for me to use J8, but i have found that sometimes even a continuous connection (more than 5 seconds) will just reset the system for a short time. This could just be me, i'm not worried about it as long as the on-off-on switch does the job for me.
    Thanks guys.
    Dan
  8. #18
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by agentloveless
    Thats to use the M1-atx to controll / turnon another device. you cannot controll the M1 with that.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  9. #19
    May 2004
    Denver
    Quote Originally Posted by WebDog
    wrong, J8 is the replacement for your front mount power switch... so it will reboot the device, it essentially is a pass through to the motherboard power jumpers...
    you must be confusing this with the remote turn on lead?? that would be J2
  10. #20
    Quote Originally Posted by mgithens
    You can do that to, but the turn on pulse from the M1-ATX also goes to J8 so it can also control another device.
    It still does not control the M1-ATX, you may be able to control the PC.
    1990 Jeep Cherokee
  1. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 06:39 AM
  2. m1 atx 90watt...is it for me?
    By psycos in forum Power Supplies
    Last Post: 08-13-2005, 11:06 AM
  3. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 03:28 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 02:22 PM
  5. ATX to AT conversion?
    By drew in forum General Hardware Discussion
    Last Post: 10-27-1999, 01:28 AM
