Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Help! Configuring M1-ATX
    May 2005
    I got a M1-ATX PSU temporary hooked up on the 12v line in my trunk. I've put anon/off switch in the + and use the PSU in mode 0 (Dumb mode)
    When both the car and the PC are running, everything is A-OK, when I turn off the car the pc stays on. But when I start the car while the PC is on the PC turns off.
    Won't the M1-ATX compensate/buffer the voltage drop on the car's battery in Mode 0? Or should I use the M1-ATX in another mode then?
    And using those mode's, which is the best setting?
    Mode = off delay / Hard Off
    0 = Traditional PSU (Domme mode)
    1 = 5 sec / 45 sec
    2 = 5 sec / 2 Hours (Recommended)
    3 = 5 sec / Never
    4 = 30 sec / 2 Hours
    5 = 30 sec / Never
    6 = 30 min / Never (Taxi Mode)
    7 = 3 Hours / Never
    If I use mode 2 my pc will shutdown 5 seconds after I get the keys out of the ignition. I don't want that, it's too fast, I don't want the pc to reboot when I'm at a gasstation or getting something quick.
    Best would be a bit of 2 modes, the Off Delay from mode 6 (30mins) and the Hardoff from mode 2 (2 Hours) Is that possible?
    Which mode do you use on your M1?
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    I have 5 sec/2 Hour option. I compensated for the 5 sec delay by installing a on-off-on switch which can:
    A- Provide constant power to the ignition wire of M1
    B- Cut power to the ignition wire of M1
    C- Conncet ignition wire of M1 to the car's ignition switch (as designed)
    -When I don't want the PC to turn off at all, switch is on "A". At a gas station I just flip the switch to A.
    -When I don't want the PC to come on, switch is on "B". Comes in handy when the car goes for repair.
    -When I want the PC to start and shut down with the car, switch is on "C". This is what it is normally set at.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    May 2005
    Do you have a howto (howto connect the wires to the on-off-on switch) for me?
    Jul 2005
    Maine, USA
    Well in order to make it work, the switch would just change the Ignition lead to the positive wire from the battery, and that will fool the m1 into thinking that the switch is on. To wire such a switch you could use a rotary switch that had three different positions, the output lead goes to the m1's ignition lead, and one of the switch's leads has the battery + wire connected (Option A), one wire has nothing (option B), and one wire has the Ignition wire (Option C).
    You may need to use relays or something to do the actual switching cutting power to the current carrying wires, but the rotary would do all the thinking.
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by Meelobee
    I have a simple toggle ON-OFF-ON switch connected as in the diagram and it is working fine:
    Edit: Looks like I messed up in naming the poles. Diagram shows location of A, B and C reversed but it does not matter as long as it is connected as shown. In here,
    A - Carputer starts and shuts down as designed whenever car is on or off
    C- Carputer never turns on
    B- Carputer is turned on and stays on even if car is turned off.
    May 2005
    Sometimes a picture is worth a thousand words Thanks!
    May 2004
    Denver
    Quote Originally Posted by Zebelkhan
    do you have a nice looking switch?? I couldn't anything nice enough that provided the on-off-on option... I was considering just jumping the "b" option on the M1-ATX, so the PS would change from "always on" to the 5sec/45sec option... so my on-off switch would work for me, also a small reset switch for booting, rebooting... does this make sense??
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by mgithens
    I just used a mini toggle switch from Radio Shack. I have it mounted on the side so it is not very visible.
    Variable Bitrate looneeii's Avatar
    Feb 2005
    Gatineau, QC, Canada
    Nice pick Zeb, the only thing is I wonder is did you just splice into the 3 cables?
    99 Grand Prix Grand Tigress
    HW
    Liliput 8in TS
    845GVD MITX w/ 2.4 Mobile P4M (478 MB)
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
    Low Bitrate agentloveless's Avatar
    Aug 2005
    So Cal
    Correct me if I am wrong but I think there is a spot for a switch on the board it self, like one of the jumpers, that allows it to stay on when you wish.
  1. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  2. m1 atx 90watt...is it for me?
    By psycos in forum Power Supplies
    Last Post: 08-13-2005, 12:06 PM
  3. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 04:28 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
  5. ATX to AT conversion?
    By drew in forum General Hardware Discussion
    Last Post: 10-27-1999, 02:28 AM
